Programmable Devices
21615 Discussions
aocl diagnose error: no drivers available inside docker container
Saikiranbelana
aocl diagnose command fails by saying Error opening AFC: no driver available
with Intel RTE stack.
root@3210051f6d19:~/intelrtestack# aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
        /etc/OpenCL/vendors
Found 1 icd entry at that location:
        /etc/OpenCL/vendors/Altera.icd
the following OpenCL libraries are referenced in the icd files:
        libalteracl.so
checking LD_LIBRARY_PATH for registered libraries:
        libalteracl.so was registered on the system at /opt/opencl_rte/aclrte-linux64/host/linux64/lib
Using the following location for fcd installations:
        /opt/Intel/OpenCL/Boards
Found 1 fcd entry at that location:
        /opt/Intel/OpenCL/Boards/dcp_bsp.fcd
the following OpenCL libraries are referenced in the fcd files:
        /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so
        /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so was registered on the system.
ERROR: OpenCL host failed
ICD diagnostics FAILED
BSP Diagnostics
Device Name:
acl0
BSP Install Location:
Vendor: Intel Corp
DIAGNOSTIC_PASSED
Device Name:
acl1
Vendor: Intel Corp
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
 the FPGAs are getting detected but aocl commands are not worlking:
root@3210051f6d19:~/intelrtestack# fpgainfo fme
Board Management Controller, microcontroller FW version 26895
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                     : 0xEF00001
PCIe s:b:d:f                  : 0000:AF:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Bitstream Id                  : 0x124000200000367
Bitstream Version             : 1.2.4
Pr Interface Id               : 38d782e3-b612-5343-b934-2433e348ac4c
Boot Page                     : user
Object Id                     : 0xEF00000
PCIe s:b:d:f                  : 0000:86:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Boot Page                     : user
please, can someone help me resolving the issue.
@intel
Thanks & Regards,
Saikiran Belana
BoonBengT_Altera
Hi @Saikiranbelana,
Thank you for posting in Intel community forum and hope all is well.
May I ask what are the OS of your host machine?
Just to double checked did you managed to install the opencl runtime driver? (may refer here for further steps)
Hope that clarify.
Best Wishes
BB
Saikiranbelana
Thank you for replying @BoonBengT_Altera ,
I have followed the reference link you have shared. The following are the same outputs/errors  I get with the reference link (please note, I'm running this on Ubuntu based docker container).
root@69b7aac9f145:~# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$INTELFPGAOCLSDKROOT/host/linux64/lib:$AOCL_BOARD_PACKAGE_ROOT/linux64/lib
root@69b7aac9f145:~# aocl install
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y
aocl install: /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp is already registered in the system, please uninstall it before reinstalling
root@69b7aac9f145:~# aocl uninstall
Do you want to unset the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] y
aocl uninstall: Removing the FPGA Client Driver (FCD) from the system
aocl uninstall: Removing the board package /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp from the list of installed packages. This process may require admin privilege
aocl uninstall: Running uninstall from /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
WARNING: uninstall not implemented.  Please refer to DCP Quick Start User Guide
for installation instructions.
aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege
Install the FCD file to /opt/Intel/OpenCL/Boards
aocl install: Adding the board package /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /root/intelrtestack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
WARNING: Intel PAC device not found
Do you want to unset the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y
root@69b7aac9f145:~# aocl install -fcd-only
root@69b7aac9f145:~# aocl diagnose
        /etc/OpenCL/vendors
        libalteracl.so
BSP Diagnostics
Device Name:
acl0
Vendor: Intel Corp
DIAGNOSTIC_PASSED
Device Name:
acl1
Vendor: Intel Corp
DIAGNOSTIC_PASSED
BoonBengT_Altera
Hi @Saikiranbelana,
Apologies for the delayed in response.
Based on the the installation and uninstallation of the driver seems not implemented with some privilege restriction.
My guess perhaps can try to check on your account access and if terminal are lunch with the right privilege.
Hope that help.
Note: If it is related to PCIe driver, would suggest to further check this session here.
Best Wishes
BB
BoonBengT_Altera
Hi @Saikiranbelana,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
BoonBengT_Altera
Hi @Saikiranbelana,
Greetings, as we do not receive any further clarification on what is provided, we would assume challenge are resolved. Hence thread will no longer be monitored. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
