21611 Discussions
arria 10 use transciever phy ip
smile123
hi,everyone,i have a issue about transciever phy ip,as follows:
    the phy ip is 2 recieve channel,but the rx_is_lockedtoref  signal of ch1 is unstable, ch0 is ok.
    At the same time,i have a phy ip is 1 recieve channel to test the ch0 and ch1, all off them is ok,What is the problem?
ZiYing_Intel
Hi smile123,
When CDR is in locked to data mode, the status of rx_is_lockedtoref is unknown; it can be high or low or toggling. You do not need to care about rx_is_lockedtoref when rx_is_lockedtodata is high.
zying
FvM
you agree that you are not giving much info about your design?
As a starter question, does your design meet timing? Do you see any warnings, e.g. related to PLL usage?
smile123
Hi,it is sorry to reply to you now,my .qar project file is below.
ZiYing_Intel
Thanks for submitting the issue. Allow me have some time to look into the issue and I will get back to you with findings.
zying
ZiYing_Intel
Hi smile123,
Can you share your .qar file here? So that I can try debug the issue from my side.
zying
smile123
Hi,this is the .qar file.
ZiYing_Intel
Hi smile123,
zying
smile123
ok,thank you for your reply。
