Programmable Devices
21615 Discussions
backspace and enter key, reset VGA in verilog HDL?
how to write codes for backspace and enter key in Verilog HDL?
and also how to reset VGA screen?
here's the sample code
i cant figure out what is wrong.
thanks!
module vga_sync(
input wire clk, reset,
output wire h_sync, v_sync, video_on, p_tick,
output wire [9:0] pixel_x, pixel_y
//constant declaration
//VGA 640-by-480 sync parameters
localparam HD = 640; //horizontal display
localparam HF = 48; // h. back(left) porch
localparam HB = 16; //h. front(right) porch
localparam HR = 96; //h. retrace (sync a)
localparam VD = 482; //vertical display
localparam VF = 33; //v. back(top)
localparam VB = 8; //v. front (bottom)
localparam VR = 2; //v. retrace (sync a)
//mod-2 counter
reg mod2_reg;
wire mod2_next;
//sync counters
reg [9:0] h_count_reg, h_count_next;
reg [9:0] v_count_reg, v_count_next;
//output buffer
reg v_sync_reg, h_sync_reg;
wire v_sync_next, h_sync_next;
//status signal
wire h_end, v_end, pixel_tick;
//body
//registers
always @(posedge clk, posedge reset)
if (reset)
begin
mod2_reg <= 1'b0;
v_count_reg <= 1'b0;
h_count_reg <= 1'b0;
v_sync_reg <= 1'b0;
h_sync_reg <= 1'b0;
end
else
begin
mod2_reg <= mod2_next;
v_count_reg <= v_count_next;
h_count_reg <= h_count_next;
v_sync_reg <= v_sync_next;
h_sync_reg <= h_sync_next;
end
//mod-2 circuit to generate 25Mhz enable tick
assign mod2_next = ~mod2_reg;
assign pixel_tick = mod2_reg;
//status signals
//end of horizontal counter (799)
assign h_end = (h_count_reg == (HD+HF+HB+HR-1));
//end of vertical counter (524)
assign v_end = (v_count_reg == (VD+VF+VB+VR-1));
//next state logic of mod-800 horizontal sync counter
always@*
if (pixel_tick) //25MHz pulse
if(h_end)
h_count_next = 0;
else
h_count_next = h_count_reg+1;
else
h_count_next = h_count_reg;
//next-state logic of mod-525 vertical sync counter
always@*
if (pixel_tick & h_end)
if (v_end)
v_count_next = 0;
else
v_count_next = v_count_reg + 1;
else
v_count_next = v_count_reg;
//horizontal and vertical sync, buffered to avoid glitch
//h_sync_next asserted between 656 and 751
assign h_sync_next = (h_count_reg >= (HD+HB) && h_count_reg <= (HD+HB+HR-1));
//v_sync_next asserted between 490 and 491
assign v_sync_next = (v_count_reg >= (VD+VB) && v_count_reg <= (VD+VB+VR-1));
//video on/off
assign video_on = (h_count_reg<HD) && (v_count_reg<VD);
//output
assign h_sync = h_sync_reg;
assign v_sync = v_sync_reg;
assign pixel_x = h_count_reg;
assign pixel_y = v_count_reg;
assign p_tick = pixel_tick;
endmodule
There is one typical syntax mistake commonly done.
You use == what is a logical equality its result can be unknown, you should better use === what is case equality and will only result in true or false
assign h_end = (h_count_reg === (HD+HF+HB+HR-1));
Next thing. inside an always construct, you better use the non blocking assignment <= instead of the single =
Your code shows only the the video synchronisation signals, but no video information itself. No RGB signal shown, i assume this must be done somewhere else where the video_on signal is use ...
`define MAXIMUM_H 80
`define MAXIMUM_V 30
//`define back_space 7'h7f
module text_pixel_generation_circuit(clk, reset, text_on, w_enable, ascii_in, pixel_x, pixel_y, text_rgb);
input clk, reset;
input text_on, w_enable;
input wire [6:0] ascii_in;
input wire [9:0] pixel_x;
input wire [9:0] pixel_y;
output reg [2:0] text_rgb;
// signal declaration
//character rom
wire [10:0] rom_address;
wire [6:0] char_address;
wire [3:0] row_address;
wire [2:0] bit_address;
wire [7:0] font_word;
wire font_bit;
// Synchronous Dual Port RAM Block declaration
reg [6:0] ram [0:4095]; // RAM text buffer
reg [11:0] write_addr; // RAM write address
reg [11:0] read_addr; // RAM read address
reg [4:0] write_row_address; // RAM write row
//wire [4:0] write_row_address_next;
reg [6:0] write_bit_address; // RAM write column
//wire [6:0] write_bit_address_next;
reg [6:0] read_data; // RAM read data
reg [6:0] write_data; // RAM write data
// tile RAM
//wire we;
//wire [11:0] address_r, address_w;
wire [6:0] d_out;
// cursor
wire cursor_on;
// delayed pixel count
reg [9:0] pixel_x1_reg, pixel_x2_reg, pixel_x3_reg;
reg [9:0] pixel_y1_reg, pixel_y2_reg, pixel_y3_reg;
// object output signals
wire [2:0] font_colour, cursor_colour;
// instantiate character ROM
character_rom character_rom_block_unit
(.clk(clk),
.address(rom_address),
.data(font_word));
// registers
always @(posedge clk)
begin
pixel_x1_reg <= pixel_x;
pixel_x2_reg <= pixel_x1_reg;
pixel_x3_reg <= pixel_x2_reg; //******
pixel_y1_reg <= pixel_y;
pixel_y2_reg <= pixel_y1_reg;
pixel_y3_reg <= pixel_y2_reg; //******
write_data <= ascii_in;
write_addr <= write_row_address * `MAXIMUM_H + write_bit_address;
read_addr <= (pixel_y >> 4) * `MAXIMUM_H + (pixel_x >> 3);
read_data <= ram[read_addr];
if (w_enable)
begin
ram[write_addr] <= write_data;
write_bit_address <= (write_bit_address == `MAXIMUM_H-1) ? 0 : write_bit_address + 1;
write_row_address <= (write_bit_address == `MAXIMUM_H-1) ? (write_row_address == `MAXIMUM_V-1) ? 0 : write_row_address + 1 : write_row_address;
end
end
// tile RAM read
assign char_address = read_data;
// character ROM
assign row_address = pixel_y[3:0];
assign rom_address = {char_address, row_address};
// use delayed coordinate to select a bit
assign bit_address = pixel_x3_reg[2:0];
assign font_bit = font_word[~bit_address];
// object signals
// green over black
assign font_colour = (font_bit) ? 3'b101 : 3'b000;
assign cursor_colour = 3'b010;
// use delayed coordinate for comparison
assign cursor_on = (pixel_y3_reg [8:4] == write_row_address) &&
(pixel_x3_reg [9:3] == write_bit_address);
// rgb multiplexing circuit
always @*
if (~text_on)
//(text_on)
text_rgb = 3'b000;
else if (cursor_on)
text_rgb = cursor_colour;
else
text_rgb = font_colour;
endmodule
module top_vga_display_controller(clk, reset, w_enable, ascii_in, h_sync, v_sync, rgb);
input clk, reset, w_enable;
output h_sync, v_sync;
output wire [2:0] rgb;
wire [9:0] pixel_x, pixel_y;
wire video_on, pixel_tick; ///
reg [2:0] rgb_reg;
wire [2:0] rgb_next; ////
// body
// instantiate vga_sync circuit
vga_sync vga_syncronization_block_unit
(.clk(clk),
.reset(reset),
.h_sync(h_sync),
.v_sync(v_sync),
.video_on(video_on),
.p_tick(pixel_tick),
.pixel_x(pixel_x),
.pixel_y(pixel_y));
// font generation circuit
text_pixel_generation_circuit text_pixel_generation_block_unit
(.clk(clk),
.reset(reset),
.text_on(video_on),
.w_enable(w_enable),
.ascii_in(ascii_in),
.pixel_x(pixel_x),
.pixel_y(pixel_y),
.text_rgb(rgb_next));
// rgb buffer
if (pixel_tick)
rgb_reg <= rgb_next;
assign rgb = rgb_reg;
endmodule
module VGA3 (clk, reset, ps2_data, ps2_clk, h_sync, v_sync,rgb);
input clk, reset;
input ps2_data, ps2_clk;
wire write_disable, write_enable;
//reg Transmit_on;
//localparam Enter_key = 8'h0A;
// body
// instantiate keyboard scan code circuit
keyboard_code keyboard_controller_block_unit
(.clk(clk),
.reset(reset),
.ps2_data(ps2_data),
.ps2_clk(ps2_clk),
.read_code(write_disable),
.write_enable(write_enable),
.ascii_code(ascii_in));
// instantiate top level vga display circuit
top_vga_display_controller vga_display_controller_block_unit
(.clk(clk),
.reset(reset),
.w_enable(write_disable),
.h_sync(h_sync),
.v_sync(v_sync),
.rgb(rgb));
always @*
if(ascii_in == Enter_key)
Transmit_on = 1;
else
Transmit_on = 0;
//assign write_disable = ~Transmit_on;
assign write_disable = ~write_enable;
endmodule
