how to write codes for backspace and enter key in Verilog HDL?
and also how to reset VGA screen? here's the sample code i cant figure out what is wrong. thanks! module vga_sync( input wire clk, reset, output wire h_sync, v_sync, video_on, p_tick, output wire [9:0] pixel_x, pixel_y ); //constant declaration //VGA 640-by-480 sync parameters localparam HD = 640; //horizontal display localparam HF = 48; // h. back(left) porch localparam HB = 16; //h. front(right) porch localparam HR = 96; //h. retrace (sync a) localparam VD = 482; //vertical display localparam VF = 33; //v. back(top) localparam VB = 8; //v. front (bottom) localparam VR = 2; //v. retrace (sync a) //mod-2 counter reg mod2_reg; wire mod2_next; //sync counters reg [9:0] h_count_reg, h_count_next; reg [9:0] v_count_reg, v_count_next; //output buffer reg v_sync_reg, h_sync_reg; wire v_sync_next, h_sync_next; //status signal wire h_end, v_end, pixel_tick; //body //registers always @(posedge clk, posedge reset) if (reset) begin mod2_reg <= 1'b0; v_count_reg <= 1'b0; h_count_reg <= 1'b0; v_sync_reg <= 1'b0; h_sync_reg <= 1'b0; end else begin mod2_reg <= mod2_next; v_count_reg <= v_count_next; h_count_reg <= h_count_next; v_sync_reg <= v_sync_next; h_sync_reg <= h_sync_next; end //mod-2 circuit to generate 25Mhz enable tick assign mod2_next = ~mod2_reg; assign pixel_tick = mod2_reg; //status signals //end of horizontal counter (799) assign h_end = (h_count_reg == (HD+HF+HB+HR-1)); //end of vertical counter (524) assign v_end = (v_count_reg == (VD+VF+VB+VR-1)); //next state logic of mod-800 horizontal sync counter always@* if (pixel_tick) //25MHz pulse if(h_end) h_count_next = 0; else h_count_next = h_count_reg+1; else h_count_next = h_count_reg; //next-state logic of mod-525 vertical sync counter always@* if (pixel_tick & h_end) if (v_end) v_count_next = 0; else v_count_next = v_count_reg + 1; else v_count_next = v_count_reg; //horizontal and vertical sync, buffered to avoid glitch //h_sync_next asserted between 656 and 751 assign h_sync_next = (h_count_reg >= (HD+HB) && h_count_reg <= (HD+HB+HR-1)); //v_sync_next asserted between 490 and 491 assign v_sync_next = (v_count_reg >= (VD+VB) && v_count_reg <= (VD+VB+VR-1)); //video on/off assign video_on = (h_count_reg<HD) && (v_count_reg<VD); //output assign h_sync = h_sync_reg; assign v_sync = v_sync_reg; assign pixel_x = h_count_reg; assign pixel_y = v_count_reg; assign p_tick = pixel_tick; endmoduleLink Copied
There is one typical syntax mistake commonly done.
assign h_end = (h_count_reg == (HD+HF+HB+HR-1)); You use == what is a logical equality its result can be unknown, you should better use === what is case equality and will only result in true or false assign h_end = (h_count_reg === (HD+HF+HB+HR-1)); Next thing. inside an always construct, you better use the non blocking assignment <= instead of the single =. Your code shows only the the video synchronisation signals, but no video information itself. No RGB signal shown, i assume this must be done somewhere else where the video_on signal is use ...- Mark as New
`define MAXIMUM_H 80
`define MAXIMUM_V 30 //`define back_space 7'h7f module text_pixel_generation_circuit(clk, reset, text_on, w_enable, ascii_in, pixel_x, pixel_y, text_rgb); input clk, reset; input text_on, w_enable; input wire [6:0] ascii_in; input wire [9:0] pixel_x; input wire [9:0] pixel_y; output reg [2:0] text_rgb; // signal declaration //character rom wire [10:0] rom_address; wire [6:0] char_address; wire [3:0] row_address; wire [2:0] bit_address; wire [7:0] font_word; wire font_bit; // Synchronous Dual Port RAM Block declaration reg [6:0] ram [0:4095]; // RAM text buffer reg [11:0] write_addr; // RAM write address reg [11:0] read_addr; // RAM read address reg [4:0] write_row_address; // RAM write row //wire [4:0] write_row_address_next; reg [6:0] write_bit_address; // RAM write column //wire [6:0] write_bit_address_next; reg [6:0] read_data; // RAM read data reg [6:0] write_data; // RAM write data // tile RAM //wire we; //wire [11:0] address_r, address_w; wire [6:0] d_out; // cursor wire cursor_on; // delayed pixel count reg [9:0] pixel_x1_reg, pixel_x2_reg, pixel_x3_reg; reg [9:0] pixel_y1_reg, pixel_y2_reg, pixel_y3_reg; // object output signals wire [2:0] font_colour, cursor_colour; // instantiate character ROM character_rom character_rom_block_unit (.clk(clk), .address(rom_address), .data(font_word)); // registers always @(posedge clk) begin pixel_x1_reg <= pixel_x; pixel_x2_reg <= pixel_x1_reg; pixel_x3_reg <= pixel_x2_reg; //****** pixel_y1_reg <= pixel_y; pixel_y2_reg <= pixel_y1_reg; pixel_y3_reg <= pixel_y2_reg; //****** write_data <= ascii_in; write_addr <= write_row_address * `MAXIMUM_H + write_bit_address; read_addr <= (pixel_y >> 4) * `MAXIMUM_H + (pixel_x >> 3); read_data <= ram[read_addr]; if (w_enable) begin ram[write_addr] <= write_data; write_bit_address <= (write_bit_address == `MAXIMUM_H-1) ? 0 : write_bit_address + 1; write_row_address <= (write_bit_address == `MAXIMUM_H-1) ? (write_row_address == `MAXIMUM_V-1) ? 0 : write_row_address + 1 : write_row_address; end end // tile RAM read assign char_address = read_data; // character ROM assign row_address = pixel_y[3:0]; assign rom_address = {char_address, row_address}; // use delayed coordinate to select a bit assign bit_address = pixel_x3_reg[2:0]; assign font_bit = font_word[~bit_address]; // object signals // green over black assign font_colour = (font_bit) ? 3'b101 : 3'b000; assign cursor_colour = 3'b010; // use delayed coordinate for comparison assign cursor_on = (pixel_y3_reg [8:4] == write_row_address) && (pixel_x3_reg [9:3] == write_bit_address); // rgb multiplexing circuit always @* if (~text_on) //(text_on) text_rgb = 3'b000; else if (cursor_on) text_rgb = cursor_colour; else text_rgb = font_colour; endmodule- Mark as New
module top_vga_display_controller(clk, reset, w_enable, ascii_in, h_sync, v_sync, rgb);
input clk, reset, w_enable; input wire [6:0] ascii_in; output h_sync, v_sync; output wire [2:0] rgb; // signal declaration wire [9:0] pixel_x, pixel_y; wire video_on, pixel_tick; /// reg [2:0] rgb_reg; wire [2:0] rgb_next; //// // body // instantiate vga_sync circuit vga_sync vga_syncronization_block_unit (.clk(clk), .reset(reset), .h_sync(h_sync), .v_sync(v_sync), .video_on(video_on), .p_tick(pixel_tick), .pixel_x(pixel_x), .pixel_y(pixel_y)); // font generation circuit text_pixel_generation_circuit text_pixel_generation_block_unit (.clk(clk), .reset(reset), .text_on(video_on), .w_enable(w_enable), .ascii_in(ascii_in), .pixel_x(pixel_x), .pixel_y(pixel_y), .text_rgb(rgb_next)); // rgb buffer always @(posedge clk) if (pixel_tick) rgb_reg <= rgb_next; assign rgb = rgb_reg; endmodule- Mark as New
module VGA3 (clk, reset, ps2_data, ps2_clk, h_sync, v_sync,rgb);
input clk, reset; input ps2_data, ps2_clk; output h_sync, v_sync; output wire [2:0] rgb; wire [6:0] ascii_in; wire write_disable, write_enable; //reg Transmit_on; //localparam Enter_key = 8'h0A; // body // instantiate keyboard scan code circuit keyboard_code keyboard_controller_block_unit (.clk(clk), .reset(reset), .ps2_data(ps2_data), .ps2_clk(ps2_clk), .read_code(write_disable), .write_enable(write_enable), .ascii_code(ascii_in)); // instantiate top level vga display circuit top_vga_display_controller vga_display_controller_block_unit (.clk(clk), .reset(reset), .w_enable(write_disable), .ascii_in(ascii_in), .h_sync(h_sync), .v_sync(v_sync), .rgb(rgb)); /* always @* if(ascii_in == Enter_key) Transmit_on = 1; else Transmit_on = 0; */ //assign write_disable = ~Transmit_on; assign write_disable = ~write_enable; endmodule
