Programmable Devices
21602 토론
can arria-10-gx run on aarch64 nvidia jetson?
AVolo2
초보자
7,965 조회수
we got this card
can it work on jetson board?
https://www.intel.com/content/dam/www/central-libraries/us/en/documents/intel-pac-with-arria-10-gx-product-brief.pdf
It is listed in lspci outputs as
0005:01:00.0 Processing accelerators: Intel Corporation Device 09c4
0 포인트
54 응답
AVolo2
초보자
2,115 조회수
@JohnT_Intel I tried asking intel regarding which OS to install
They pointed to Ubuntu 18.04
Shall I repeat? Which exactly OS [exact OS image [iso]will work with the PAC ? In a way the installation script will install everything including the driver?
0 포인트
JohnT_Intel
직원
2,101 조회수
For standard installation, it is supporting Ubuntu 18.04. You may refer to https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/system-requirements.html
0 포인트
AVolo2
초보자
2,092 조회수
Hello
Coud you confirm
That on 18.04 not only opae-sdk installs with linux-dfl from opae repository
But the intel setup script install also installing linux-dfl from dev stack install script, please?
Other Intel folks pointed out that intel dev stack install script doesn't install linux-dfl at any OS as I understand
Moreover installing it manually from opae-sdk results in nothing but in boot error when booting from linux -dfl kernel.
Any ideas?
-BR
AV
0 포인트
JohnT_Intel
직원
2,082 조회수
The 18.04 is for the OPAE-SDK and not the linux-dfl. The reason is that the PAC installation package will have their own driver. The OPAE in github driver is linux-dfl.
I would recommend to try using the installation package to make sure everything works before moving to OPAE github version
0 포인트
AVolo2
초보자
2,074 조회수
I was pointed out by Intel folks that installation of linux dfl driver is not supported from the intel installer [ it results in error]
0 포인트
JohnT_Intel
직원
2,071 조회수
The linux-dfl and PAC installation is using different driver. Linux-dfl is a open source driver that can work with Intel PAC card.
0 포인트
AVolo2
초보자
2,062 조회수
Is it possible to implement the PAC installation
using the intel script on any specific OS?
So that everything including the kernel/ drivers gets installed from the intel script?
Or that is not supported on any OS?
0 포인트
JohnT_Intel
직원
2,054 조회수
If you are using the below OS then you should be able to follow the installation guide in https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/installing-the-opae-software-package.html
  • Red Hat* Enterprise Linux* (RHEL) 7.6, kernel version 3.10.0-957
  • Ubuntu* 18.04, kernel 4.15
0 포인트
AVolo2
초보자
2,046 조회수
@JohnT_Intel We are having hard times getting the package bw2tk-lite-2018.6.u1604.amd64.deb through a registration at third party website that doesn't seem functioning for getting through register-download cycle.
Could you share the package for flashing the firmware please ?
0 포인트
JohnT_Intel
직원
2,041 조회수
Can you move forward without installing "bw2tk-lite-2018.6.u1604.amd64.deb"?
0 포인트
AVolo2
초보자
2,032 조회수
Hi @JohnT_Intel
Thank you for following up.
The problem was that the firmware seems was for 1.0 which would cause some mismatch[ see screenshot from devs]
So we would wish to upgrade it to compatible with 1.2.1
However, it was possible to download the bw2tk package from community forum, although it would be more like for ubuntu 16.04 so may have some issues with compatibility.
0 포인트
AVolo2
초보자
2,023 조회수
our dev requests documentation for  A10SA4
due to some reason they can only flash 1.2 firmware but not 1.2.1
0 포인트
JohnT_Intel
직원
2,017 조회수
You need to download the file from https://developer.bittware.com/home.php
0 포인트
응답
