Programmable Devices
21611 Discussions
clock timing measurement
my aim is to see how many clock cycles it takes for my C code to execute.
How can I do this?.
I have no block design file, I'm using an verliog code as top level design, and a C code to download into processor and make the fucntion(verilog+c code) to work.
It works perfectly, which I want.
My question, is..
How can I know How many clock cycles it takes for my C code to execute the function(logic) which I want?.
waiting for your reply guys.
thanks,
Ana
If you're using NIOS 2 there is a profiler component (performance counter unit) you can add to your system. I've never used it myself so I don't know how it works.
I guess you could make one of those yourself, a write to a sopc component would start a counter and then with another write stop it and read out the value. A start and stop of the timer would give you an estimate of the avalon overhead.
You could also use a timer in your NIOS 2 core to see how long time the program takes to execute and then estimate the number of cycles.
I hope this helps
thanks, i will try it out.
should I give the base address of PERFORMANCE_COUNTER_0_BASE, or wil it get it automatically from system.h,
If I dont declare it gives me an error saying " first use of this function" PERFORMANCE_COUNTER_0_BASE
If I declare this with its base address like.
# define PERFORMANCE_COUNTER_0_BASE 0x00021000
it builds and runs but I get an output where the output runs like :
yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
why is this because of ?.
waiting for your reply.
thanks,
Anand
I don't know, as I said I never needed to use it. There should be some documentation for the component somewhere on Alteras homepage. If you don't need exact statistics you can try the other methods I suggested.
//Ola
