Programmable Devices
21583 討論
convert .vhd to .bdf
榮譽貢獻者 II
4,854 檢視
How i can convert a .vhd file to .bdf?
0 積分
9 回應
榮譽貢獻者 II
3,020 檢視
It can't be done in that direction. If you want a graphical view of VHDL code, you can use the RTL viewer after synthesis. But it's not always easy to read
榮譽貢獻者 II
3,020 檢視
My question is how to create a project made in vhdl code in a block schematic representation......it can't be made by do create/udate->create ymbol files for current fle?
榮譽貢獻者 II
3,020 檢視
--- Quote Start ---
--- Quote End ---
as Daixiwen mentioned it is not possible to convert a project written in VHDL into a schematic. Why do you want a schematic ? Only to get an overview of the struture of
your design? As Daixiwen mentioned you can use the RTL viever of Quartus for that purpose.
Kind regards
GPK
榮譽貢獻者 II
3,020 檢視
Iam making a bigger project in block diagram schematic file form and i want to add this .vhd project file to it....
榮譽貢獻者 II
3,020 檢視
In that case yes you can right click on the vhdl file in quartus and select "Create Symbol Files for Current File". It will create a bsf file that is a block you can add to your block diagram schematic file.
榮譽貢獻者 II
3,020 檢視
Thanks this seems to work!!!!
榮譽貢獻者 II
3,020 檢視
--- Quote Start ---
--- Quote End ---
then create a symbol of your VHDL project and instanciate it in your schematic:
File -> Create/Update -> Create Symbofile for current file
This option is only active when you open the designfile !
I have a small project attached. It uses Verilog, but there is no difference for
Symbol generation.
Kind regards
GPK
榮譽貢獻者 II
3,020 檢視
When I try this conversion from vhdl to bsf (symbol) the file>create/update has all menu entries are greyed out (not selectable). What is the trick to creating a symbol?
榮譽貢獻者 II
3,020 檢視
Is the file part of the project?
回覆
