Programmable Devices
21615 Discussions
gate level simulation error
Hi all,
i have a problem in gate level simulation.
actually i have two kits
1- cyclone IV gx EP4CGX150DF31C7 kit
2- SDALTEVK (ti) sdi kit.
both kits can be connected through HSMC, during pin planning, i configure sdaltevk hsmc connection to cyclone iV hsma.
after that i got some error which is as.
Error (169079): Pad 325 of non-differential I/O pin 'genlock_no_ref' in pin location D29 is too close to pad 321 of differential I/O pin 'tx_d_p[1]' in pin location K26 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 325 of non-differential I/O pin 'genlock_no_ref' in pin location D29 is too close to pad 322 of differential I/O pin 'tx_d_n[2]' in pin location J26 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 325 of non-differential I/O pin 'genlock_no_ref' in pin location D29 is too close to pad 323 of differential I/O pin 'tx_d_p[2]' in pin location K25 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 325 of non-differential I/O pin 'genlock_no_ref' in pin location D29 is too close to pad 320 of differential I/O pin 'tx_d_n[1]' in pin location K27 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 324 of non-differential I/O pin 'genlock_no_lock' in pin location D30 is too close to pad 320 of differential I/O pin 'tx_d_n[1]' in pin location K27 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 324 of non-differential I/O pin 'genlock_no_lock' in pin location D30 is too close to pad 321 of differential I/O pin 'tx_d_p[1]' in pin location K26 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 324 of non-differential I/O pin 'genlock_no_lock' in pin location D30 is too close to pad 322 of differential I/O pin 'tx_d_n[2]' in pin location J26 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 324 of non-differential I/O pin 'genlock_no_lock' in pin location D30 is too close to pad 323 of differential I/O pin 'tx_d_p[2]' in pin location K25 -- pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 329 of non-differential I/O pin 'sdi_ck_sel0' in pin location C29 is too close to pad 331 of differential I/O pin 'tx_d_n[3]' in pin location H25 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 329 of non-differential I/O pin 'sdi_ck_sel0' in pin location C29 is too close to pad 332 of differential I/O pin 'tx_d_p[3]' in pin location J25 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 328 of non-differential I/O pin 'sdi_ck_sel1' in pin location C30 is too close to pad 331 of differential I/O pin 'tx_d_n[3]' in pin location H25 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 328 of non-differential I/O pin 'sdi_ck_sel1' in pin location C30 is too close to pad 332 of differential I/O pin 'tx_d_p[3]' in pin location J25 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
Error (169079): Pad 328 of non-differential I/O pin 'sdi_ck_sel1' in pin location C30 is too close to pad 323 of differential I/O pin 'tx_d_p[2]' in pin location K25 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
Error (168002): Live I/O check failed
check attached schematic for both kits and then give me solution what can i do fir this ??
Add an "IO_MAXIMUM_TOGGLE_RATE" attribute, to each of the non-differential signals listed, and set it to "0 MHz". You can do this through the Pin Planner (enter "0" [zero] in the 'Toggle Rate' column for the relevant signal) or directly in the .qsf. You should end up with a .qsf entry, for each signal, similar to:set_instance_assignment -name IO_MAXIMUM_TOGGLE_RATE "0 MHz" -to genlock_no_ref
Looking at the names of all your culprit signals, this attribute looks to be valid.
Cheers,
Alex
HI Alex,
this for your ans, it really works for me.
after this i have new error while programming file generation.
Internal Error: Sub-system: ASMDB, File: /quartus/db/asmdb/asmdb_mux.cpp, Line: 363
ASMDB_MUX error: ENCODED_MUX::select : index out of range (index = 16, size = 16) : last archgroup encountered: type = PLL_VOLTAGE_REGULATOR_STINGRAY, block_type = GENERAL_PLL
Stack Trace:
0x2826a: ASMDB_MUX::internal_error + 0x83a (db_asmdb)
0x28611: ASMDB_ENCODED_MUX::select + 0x61 (db_asmdb)
0x13a33: ASMDB_ARCH_GROUP_STD::select + 0x153 (db_asmdb)
0x1e578: ASM_ARCH_GROUP::mux_select + 0xd8 (comp_asmcc)
0x1289d8: ASM_LAB_BITS::get_row_size + 0x9e08 (comp_asm)
0x20577f: ASM_AVALON_SPACE::operator= + 0x121f (comp_asm)
0x207444: asm_process_sof + 0xb04 (comp_asm)
0x20a511: asm_process_sof + 0x3bd1 (comp_asm)
0x20d451: asm_assemble + 0x3e1 (comp_asm)
0x12718: QEXE_ARGS::get_command_line + 0x1ca8 (comp_qexe)
0x15a7a: qexe_process_cmdline_arguments + 0x5aa (comp_qexe)
0x15b91: qexe_standard_main + 0xa1 (comp_qexe)
0x4e88: msg_exe_fini + 0x58 (CCL_MSG)
0x56cc: msg_exe_fini + 0x89c (CCL_MSG)
0x1614: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x1a4 (ccl_mem)
0x62ff: msg_exe_main + 0x8f (CCL_MSG)
0x1652c: BaseThreadInitThunk + 0xc (kernel32)
0x2c520: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus II 64-Bit Version 12.1 Build 243 01/31/2013 SJ Web Edition
Service Pack Installed: 1
what i do for this ??
That is a crash. You need to try a different version or raise a support ticket with altera.
hi,
before i am using 12.1 SP1 and now i am using 15.1 after update tool this error again comes.
what we do next ?
--- Quote Start ---
hi,
what we do next ?
--- Quote End ---
Like I said - it is a crash - you need to raise a case via altera mysupport
My question would be why are you running gate level simulations to begin with?
