Programmable Devices
21602 Discussions
generate problem
Hi friends,
I try to replicate a module by N (parameter) times. Each small instance is connected (wire) with prev and next. In original design (fixed 8 cells) I just declared 8 wires
wire out7, out6, out5, out4, out3, out2, out1, out0;
But how can I do now when I am (try to be) parametrized?
generate
for ( i = 0; i <= N-1; i = i+1 )
begin: inst
shiftcell (
.Load(Load),
.Clock(invSCK),
.Din(DataIn[i]),
.Prev(Serial_In),
.Dout(out7)
end
endgenerate
For out7 wire name I need somehing like out{i}. Thanks very much for help in advance.
Obviously, you need to declare your wire variable as a vector.
Perhaps zuzu22 wants to say that he is constrained to use out7 from the external design.
He can generate the architecture using out[7] but he then needs a module that translate these signal inputs in out7.
It seems that he wants to "construct" the name of the signal using "i".
I don't know how to solve the problem, however.
Thank you very much FvM, it worked nice. A small problem now
Critical Warning (10846): Verilog HDL Instantiation warning at shifterNmsb.v(45): instance has no name
wire w[N:0]; // N+1 wires
generate
begin: inst
shiftcell (
.Load(Load),
.Clock(invSCK),
.Din(DataIn),
.prev(w),
.Dout(w[i+1])
end
endgenerate
--- Quote Start ---
--- Quote End ---
True indeed. Something like shiftcell shiftcell_inst ()
Oukey, thanks again, solved (without underscore)
shiftcell inst (
