Programmable Devices
21615 Discussions
generating vcd or saf file.
I tried generating vcd file in ModelSim and used the same to calculate power in Altera Quartus II. But the level of confudence was low. Is there any method by which the confidence level can be improved? Can a saf file be generated in Quartus II, other than using PowerPlay Analyser tool?
