21611 Discussions
how can “EPCQ“” Flash store both FPGA Image and customer user parameters ?
JET60200
dear,
our A10 GX board has an EPCQ1024L Flash, we can burn FPGA image into it and power up board to run it successfully.
Now we have some customer parameters which needs to be stored on-board flash as well. so we wanto divide this EPCQ1024L Flash into two parts, one part is to store FPGA image, and the other part is to store some customer data for every special board.  How can we get it ?  Is there any guide to realize it ?
thanks in advance
NurAiman_M_Intel
Thank you for contacting Intel community.
Kindly refer to AN370 below for Using the Intel FPGA Serial Flash Loader with the Intel Quartus Prime Software:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an370.pdf
On top of that, please set a specific address in Convert Programming Files and reboot the EPCQ flash from that particular address..
Aiman
JET60200
hi @NurAiman_M_Intel , thanks for reply,
Even though we can boot up fpga from the serial flash device with a specified starting address, how can FPGA access (i.e read ) that "customer parameter partition" in serial flash when FPGA runs up ?  Is there any exampe from FPGA side to read/write the serial flash ?
WE need fpga to read customer parameters & data  wich stored inside the serial flash //
Thanks in adv
NurAiman_M_Intel
NurAiman_M_Intel
To access read and write flash, you will need to use configuration IP.
Example:
Serial Flash controller ii IP
You need to write your own RTL code to read and write flash using this IP.
Aiman
JET60200
Thanks @NurAiman_M_Intel for reply,
    if there's an example design which demostrate the usgae of "Serial Flash IP", which will be great helpful as well.
NurAiman_M_Intel
You don't really have to use serial flash IP. You may also use other IP for your design. Below are the link to design references:
https://fpgacloud.intel.com/devstore/platform/18.1std.1/Standard/generic-serial-flash-interface-and-nios-ii-booting/
https://fpgacloud.intel.com/devstore/platform/17.0.0/Standard/cyclone-10-lp-remote-system-update-design-example/
Aiman
