Programmable Devices
21607 Discussions
how can i get about 100Mbps~200Mbps TCP traffic using Ethernet ?
Hi :
I want to use Ethernet to transmit huge of data (after AD processing) to PC. It is better to get about 100Mbps~200Mbps TCP traffic .I think it's hard for Nios II system to get this speeed .
Do you have any feasible scheme about this problem ? Does anyone have achieved this speed ?
Now ,I have cyclone III and Stratix II ,LAN91C111 and Triple speed Ethernet IP CORE.
Best Regards
-poseidon
application note 440 (http://www.altera.com/literature/an/an440.pdf), page 18, gives some results that you can expect with a Nios CPU on a Stratix II.
--- Quote Start ---
--- Quote End ---
Thank you Daixiwen .I will take a gook look at this Document.
Best Regard
-poseidon
--- Quote Start ---
--- Quote End ---
If i use DMA,do you think this schema could be more faster?
nioswiki has a great example using UDP. The example gets line rate at 1Gbps.
The ethernet MAC does use DMA.
Jake
--- Quote Start ---
Jake
--- Quote End ---
yea ,I found it use SGDMA after reading the TSE document.
My boss think it is better to use pure hardware implement to improve faster TCP traffic ,So.i will have a try to write TCP AND ARP model by Verilog or VHDL .Does anyone have seen documents about how to do this ?
--- Quote Start ---
--- Quote End ---
Thank you ,But I have to use TCP that Provide reliably data transmit.
You're in for some pain. TCP is non-trivial.
Jake
--- Quote Start ---
--- Quote End ---
I didn't found this example. Where in wiki nios is it?
I'm sorry, i found the page.
--- Quote Start ---
--- Quote End ---
http://www.nioswiki.com/exampledesigns/nios2udpoffloadexample
--- Quote Start ---
--- Quote End ---
in Wiki Nios page, try to search for "udp". You will find some links, take a look at those with the tags "udp" and "offload". There is a documentation (some explain about the code) and the example (code and an executable).
Hope it can help you :D
Oh, i'm sorry. :p:p:p
Thanks, Poseidon!
