Programmable Devices
公告
21615 讨论
how to achieve 4 channel LVDS ADC read
XQSHEN
新手
3,742 次查看
ADC: TI  ADC3422 , 4 channel 12 bit ADC with 50M sample rate, LVDS
FPGA: Intel EP4CE15M9I7N
To read this ADC, so the clock should be as fast as 150MHz at rising and falling edge.
Is there any special IP as DDR RAM ALTPHY required?
Can EP4CE15M9I7N support four channels LVDS up to 150MHz read?
0 项奖励
1 解答
EngWei_O_Intel
3,716 次查看
Hi there
Since the LVDS support up to deserialization factor of 10, you can refer to link below to compute for other factors:
https://www.youtube.com/watch?v=02lgfcxSjQA
For the spec you mentioned, Cyclone IV shall be supported.
在原帖中查看解决方案
0 项奖励
2 回复数
EngWei_O_Intel
3,717 次查看
Hi there
0 项奖励
XQSHEN
新手
3,692 次查看
In adc spec, there is frame clock output, but I am not sure which signal in IP ALTLVDS_RX could match it?
0 项奖励
回复
