ADC: TI ADC3422 , 4 channel 12 bit ADC with 50M sample rate, LVDS
FPGA: Intel EP4CE15M9I7N
To read this ADC, so the clock should be as fast as 150MHz at rising and falling edge.
Is there any special IP as DDR RAM ALTPHY required?
Can EP4CE15M9I7N support four channels LVDS up to 150MHz read?
Hi there
Since the LVDS support up to deserialization factor of 10, you can refer to link below to compute for other factors:
https://www.youtube.com/watch?v=02lgfcxSjQA
For the spec you mentioned, Cyclone IV shall be supported.
链接已复制
Hi there
In adc spec, there is frame clock output, but I am not sure which signal in IP ALTLVDS_RX could match it?
