21462 Discussions
how to instantiate the Altera v17.0 pll in the verilog file.can i get the instantiation code.
JGeor12
ak6dn
Valued Contributor III
Do you use the Tools / IP_Catalog MegaWizard to generate the PLL configuration in the QuartusII tool?
If not, you should.
It can generate a template Verilog instantiation file for you.
Vicky1
Correct, Please check the 'Generate' Menu of Platform Designer-> 'Show Instantiate Template' as shown below & provide the 'Top level design signals/wires for instantiation inside braces as highlighted, Template my vary depends on PLL configuration.
For IP Catalog,
Vicky
