21602 Discussions
input[7..0] to output[0..7]
can i connect in .bdf file 2 bus in this mode?
input[7] -> output[0]
input[6] ->output[1]
input[0] ->output[7]
is this the right text mode?
input[7..0] output[0..7]
If, by text mode, you mean AHDL - then the answer is yes.
No, i do not want edit the verilog code.
I want invert bus in bdf file
Connect input[7..0] and output[0..7] bus lines through a SOFT buffer
Tnk-you for reply, but i am a novice altera developer.. :(
what is a SOFT buffer?
regards
It is a virtual buffer that will be eliminated by logic synthesis. You find it in Primitives->Buffer section of bdf editor symbol libraries.
Its purpose is only to allow you to connect traces with different names.
tnks .
regards
