Programmable Devices
21611 Discussions
logic primitives iobuf help
the quartus help not give the truth table for this part. give only little information .
https://www.alteraforum.com/forum/attachment.php?attachmentid=7738
https://www.alteraforum.com/forum/attachment.php?attachmentid=7737
and were is OE pin ? . and how to active or disable output "i mean the output activated with high or low pulse "
This one is used for bi-directional signals. You have enable signal to choose direction as well as input and output signal to your internal logic. The bi-directional signal goes to outside pin.
--- Quote Start ---
--- Quote End ---
the enable signal high or low
If it's low, the primitive works as input buffer to fpga. It it's high, the primitive is output buffer.
--- Quote Start ---
--- Quote End ---
thank you for helping me
but from were you got this information. because i can't find this information
The signal polarity is obvious from the definition. All control signals have positive polarity unless explicitely inverted. A signal "oe" does what it's name tells.
