21384 Discussions
<terminated>nios Nios II Hardware configuration[ Nios II Hardware] nios II download
RWang54
I used Nios II system to try and build a project and download it onto the FPGA board. But when I tried to run the program in Eclipse, the process is terminated at around 64%, and the only message I get in the console is:
"Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x000000A8: verified
Starting target processor"
What could I be doing wrong?
Ahmed_H_Intel1
Hi, Please check the JTAG frequency, this might be the root cause for this. To change the JTAg frequency open the command shill and use the following command: jtagconfig --setparam <cable number> JtagClock <frequency><unit prefix>
