21615 Discussions
max v tri-state i/o
Hi, I need to use the tristate i/o feature of max v and can't seem to find the i/o block in the megawizard library.
Anybody know how to use the feature ?
What do you mean? An output is usually tristated in behavioral code, e.g. pin <= 'Z'
I have a pin which is both an input and an output. In certain clock cycles the block reads the value and in others it drives it.
--- Quote Start ---
--- Quote End ---
Then you would drive the signal with a tri-state that has an output-enable, i.e., in VHDL
bidir <= 'Z' when (enable = '0') else output;
and you can read bidir as an input at any time; when enable = '0' you are reading what is driven onto the pin by the external device, and when enable = '1', you will read what you are driving on 'output'. You can turn on the 'weak pull-up' or 'bus hold' on the pin for bidir so that it is always in a valid logical state.
Cheers,
Dave
Dave, will the Fitter automatically map my enable signal to the output enable of the i/o block ? Because in the pin assignment editor i don't see an option.
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
Why don't you just implement a simple circuit and watch the results in the Quartus netlist? Honestly, I can't imagine how Quartus would implement a tri-state driver without connecting the output enable. Can you?
I can easily imagine that some obscure command may be necessary to do this. And yes, looking at the netlist would probably clarify the issue.
--- Quote Start ---
--- Quote End ---
Correct, the netlist shows the assignment it done automatically.
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
I can't remember needing obscure commands for standard logic functionality with Altera Quartus. May be for some very special one.
