Dear,
10M08SCU169I7G with vccio1B=1.8v; vccio8=3.3V (vccio1a=2.5v)Configuration pins are in banks 1B + 8
Quartus prime 18.0 standard build 614
Warning (169202): Inconsistent VCCIO across multiple banks of configuration pins. The configuration pins are contained in 2 banks in 'Internal Configuration' configuration scheme and there are 2 different VCCIOs.
Stefan
Hi Stefan,
The problem of this warning ID because the configuration pins are powered by different Vccio in different banks.
Solution: Enforce a configuration voltage level in the Configuration tab
Cheers
Hello Shafiq,
Pin-planner signal list shows vccio1b=1.8 and vccio8=3.3 because I defined these io-standards on their signals in assignment-editor.
assignments > device > device and pin options > configuration : in this screen I tried with box checked/unchecked "Force Vccio to be compatible with configuration IO-voltage: but this gives no difference .... I don't see anything else I that relates to Vccio 0 config pins ? ?
Stefan
Hi Stefan,
The issue is the configuration pins are powered by different Vccio.
Have you tried use the same voltage for I/O bank 1B and I/O bank 8? If yes, is it able to solve the issue?
Hi Stefan,
I'm apologize to take so much time to get the confirmation regarding to this issue. I tested on my side and get the further confirmation from my colleague.
The rule of thumb: The VCCIO for bank 1B (bank 1 for 10M02 devices) and bank 8 must be powered up to a voltage between 1.5V – 3.3V during configuration.
Thus, as long as your Bank 1B & Bank 8 is powered up between that range, you are allowed to have different voltage or same voltage.
When I did the duplication on my side, I also got the same warning as yours:
Actually the warning that you get[Warning (169202)], is the false warning from Quartus. Quartus software Team will fixed it this false warning in future Quartus release.
You may refer to this KDB:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/-warning--169202---inconsistent-vccio-across-multiple-banks-of-c.html?wapkw=warning%20169202
I'm apologize for inconvenience.
Hello Shafiq, ok issue clarified. I understand this is a false warning and it will be solved in a future Quartus release. By the way I also tried with Quartus19.1 standard edition but false warning is still there.
Regards, Stefan
Hi Stefan,
The issue has not been solved in Quartus 19.1 standard.
This warning will be remove in a future release of the Quartus standard
This problem is still present in Quartus 23.1std.1 Build 993 SC Standard Edition.
Barbara
