21590 Discussions
memory initializing into 16-words per line instead of 4 words (initialize from ihex)
This seems strange. In ModelSim (and Quartus, I beleive), our *.hex files initialize what seems to be in 16-word blocks rather than 4-word blocks. I've attached a screenshot each.
As you can see, the first two lines of the ihex file is:
[word0], [word1], [word2], [word3]
BUT the memory appears as:
[word0], [word1], [word2], [word3], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000], [0x0000]
Basically, for each line in the ihex file (4 words), there are 16 words written to memory. These 16 are the original 4 words, then 12 words of zeros.
Has anyone else had this problem or know how to fix it?
** Update: In Quartus, this seems to be resolved by Assignments>Settings>Compilation Process Settings> More Settings> Reading or writing Hexadecimal(.hex) File in byte addresable mode On. However, this option is not available in ModelSim.
There seems to be a discrepancy in words size, byte versus double word addressing. Please show the memory definition.
FvM,
I've attached both the RAM generation file and the Intel hex file...
One solution we thought of is to simply skip 12 addresses at a time:
assign reduced_addr = {addr[31:4],2'b0,addr[3:2]}; // this converts 16-word addressing into 4-word addressing
This works, but we lose 75% of available memory doing so.
