21615 Discussions
not flashing the altera chip on the boards correctly
PL-USB2-BLASTER
Per customer
" We received these parts (PL-USB2-BLASTER) but are having issues. They aren't flashing the altera
chip on the boards correctly. Is this a newer revision than we ordered last time? Are they supposed to work with all operating systems? All 4 units are acting the same."
Please assist. thanks!
ak6dn
Valued Contributor III
You have not provided anywhere near enough info for anyone to comment reasonably. So...
What are exact part numbers of the Altera/Intel devices that are at issue?
What are the boards? Are they OTS development boards or customer custom boards?
What programming software version are you using (ie, which version of Quartus)?
What is the operating system and its version number?
Are there any error or warning messages shown?
PL-USB2-BLASTER
I will forward your questions to our customer for more detail information & update you.
thanks!
PL-USB2-BLASTER
Unfortunately, our customer have not provided any feedback at this time. I will update you once the answers to your question were provided.
Thanks!
NurAiman_M_Intel
Thank you for contacting Intel community.
Please provide further information per @ak6dn mention. In the meantime, you can also refer to USB Blaster II userguide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf
Aiman
NurAiman_M_Intel
Is there any update to this case? Else, I will continue to close this case. You may open a new case if you need further information.
Aiman
PL-USB2-BLASTER
Hello Aiman,
Unfortunately, our customer failed to respond to your inquiry after we contacted them multiple times.
Thanks for your support!
