Hello
I have board contain startix II fpga. when I was downloading the .pof file by the usb blaster the electricity went off. after I got the power the fpga didn't work :cry:. even I reinstalled the .pof file and I had a 100% complete but it isn't working. can any one please help me to reset the fpga .Link Copied
--- Quote Start --- I have board contain startix II fpga. when I was downloading the .pof file by the usb blaster the electricity went off. after I got the power the fpga didn't work :cry:. even I reinstalled the .pof file and I had a 100% complete but it isn't working. can any one please help me to reset the fpga . --- Quote End --- If you were loading a .pof, then you were not programming the Stratix II, but its configuration device. If the configuration device has a corrupted file, then the FPGA should detect this, and simply not configure, i.e., assert nSTATUS to indicate a bad programming file. Use JTAG to load a .sof into the FPGA, and then program the .pof into the external configuration device. Cheers, Dave
Thank you Dave, that was helpful :D.
