Programmable Devices
21615 Discussions
problem with adaptive FIR ,i realy need your help
hi all guys,i'm freshmem in forum,i got a problem with my vhdl code about adaptive FIR filter.I try write by myself but it fail (simulate in modelsim-altera),so that i write agian based on "dsp with fpga" but i found the error in that code
library IEEE;use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; entity ab is port ( xin :in std_logic_vector(7 downto 0); clk: in std_logic; y :out std_logic_vector(7 downto 0); y1 : out std_logic_vector(7 downto 0)); end ab; architecture Behavioral of ab is subtype n1bit is std_logic_vector(7 downto 0); type array_n1bit is array(0 to 2) of n1bit; signal x : array_n1bit; signal f : array_n1bit :=((others=> (others=>'0'))); begin process begin wait until clk='1'; x(0)<=xin; x(1)<=xin; f(0)<=f(0)+x(0); --f(1)<=f(1)+x(1); end process; y<=f(0); y1<=f(1); end Behavioral;
i separate the orignal code and found that error is about f(1),f(0) but i don't know how to solve this situation(i had complie but there are no errors, when testbench waveform the output alaways xxxxxx......) ,please hepl me,thanks
I'm not sure how the code is related to "adaptive FIR", but there are no syntax errors.
--- Quote Start ---
--- Quote End ---
yeah,but when i simulate ,it's wrong,the output just xxxxxxxxx.....
O.K., I see, but it's a pure functional simulation problem.
In first clock cycle, uninitialized x(0) and x(1) are added to f(0) and f(1). You easily find the problem looking at all design nodes in simulation, not just the output.
You had saved your and my time by giving a clear problem description in your first post.
--- Quote Start ---
--- Quote End ---
yeah,but how to solve this sitiation,here is totally code
---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use ieee.std_logic_signed.all; entity firlms is generic(W1: integer :=8; W2: integer :=16; L: integer :=2); port ( clk : in std_logic; x_in: in std_logic_vector(W1-1 downto 0); d_in: in std_logic_vector(W1-1 downto 0); y_in : in std_logic_vector(W2-1 downto 0); e_out,y_out,e1,y1:out std_logic_vector(W2-1 downto 0)); end firlms; architecture Behavioral of firlms is component mult port ( dataa : in std_logic_vector(7 downto 0); datab : in std_logic_vector(7 downto 0); result : out std_logic_vector(15 downto 0)); end component; subtype n1bit is std_logic_vector(W1-1 downto 0); subtype n2bit is std_logic_vector(W2-1 downto 0); type array_n1bit is array(0 to L-1) of n1bit; type array_n2bit is array(0 to L-1) of n2bit; signal d,k :n1bit; signal emu : n1bit; signal y,sxty:n2bit; signal e,sxtd:n2bit; signal x: array_n1bit; signal f : array_n1bit :=((others=> (others=>'0'))); signal p,xemu:array_n2bit; begin dsxt:process(d) begin sxtd(7 downto 0)<=d; for k in 15 downto 8 loop sxtd(k)<=d(d'high); end loop; end process; store:process begin wait until clk='1'; --y <= y_in; d <= d_in; x(0) <= x_in; x(1) <= x(0); f(0)<=f(0)+xemu(0)(15 downto 8); f(1)<=f(1) +xemu(1)(15 downto 8); end process store; --y<=p(0)+p(1); ysxt:process(y) begin sxty(8 downto 0)<=y(15 downto 7); for k in 15 downto 9 loop sxty(k)<=y(y'high); end loop; end process; e<=sxtd-sxty; emu<=e(8 downto 1); mulgen2:for i in 0 to L-1 generate fir: mult port map (dataa=>x(i),datab=>emu,result=>xemu(i)); end generate; --y_out<="00000000"&xemu(1); --e_out<="00000000"&xemu(0); e1<="00000000"&f(1); y1<="00000000"&f(0); end Behavioral; ------------------------------------------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; entity mult is port ( dataa : in std_logic_vector(7 downto 0); datab : in std_logic_vector(7 downto 0); result : out std_logic_vector(15 downto 0)); end mult; architecture fpga of mult is begin result<=dataa*datab; end fpga; -----------------------------------------------------------------------------------------------------------------
It is easily fixed - just give X(0) and (1) an initial value.
signal x : array_n1bit := (others => (others => '0'));
--- Quote Start ---
--- Quote End ---
can you show me your wave form ,i'm not next to my computer
I havent made a wave form - thats your job...
--- Quote Start ---
--- Quote End ---
it work!!!!!!!!!!!!!!!!!!!!!! thanks so much
--- Quote Start ---
--- Quote End ---
Hello, can you share the code please ? i'm trying to use it on a nexys 4 ddr. thank you
