hi all guys,i'm freshmem in forum,i got a problem with my vhdl code about adaptive FIR filter.I try write by myself but it fail (simulate in modelsim-altera),so that i write agian based on "dsp with fpga" but i found the error in that code
library IEEE;use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
entity ab is
port ( xin :in std_logic_vector(7 downto 0);
clk: in std_logic;
y :out std_logic_vector(7 downto 0);
y1 : out std_logic_vector(7 downto 0));
end ab;
architecture Behavioral of ab is
subtype n1bit is std_logic_vector(7 downto 0);
type array_n1bit is array(0 to 2) of n1bit;
signal x : array_n1bit;
signal f : array_n1bit :=((others=> (others=>'0')));
begin
process
begin
wait until clk='1';
x(0)<=xin;
x(1)<=xin;
f(0)<=f(0)+x(0);
--f(1)<=f(1)+x(1);
end process;
y<=f(0);
y1<=f(1);
end Behavioral;
i separate the orignal code and found that error is about f(1),f(0) but i don't know how to solve this situation(i had complie but there are no errors, when testbench waveform the output alaways xxxxxx......) ,please hepl me,thanks
I'm not sure how the code is related to "adaptive FIR", but there are no syntax errors.
--- Quote Start --- I'm not sure how the code is related to "adaptive FIR", but there are no syntax errors. --- Quote End --- yeah,but when i simulate ,it's wrong,the output just xxxxxxxxx.....
O.K., I see, but it's a pure functional simulation problem.
In first clock cycle, uninitialized x(0) and x(1) are added to f(0) and f(1). You easily find the problem looking at all design nodes in simulation, not just the output. You had saved your and my time by giving a clear problem description in your first post.- Mark as New
--- Quote Start --- O.K., I see, but it's a pure functional simulation problem. In first clock cycle, uninitialized x(0) and x(1) are added to f(0) and f(1). You easily find the problem looking at all design nodes in simulation, not just the output. You had saved your and my time by giving a clear problem description in your first post. --- Quote End --- yeah,but how to solve this sitiation,here is totally code
library IEEE;
use IEEE.STD_LOGIC_ARITH.ALL;
entity firlms is
generic(W1: integer :=8;
W2: integer :=16;
L: integer :=2);
port ( clk : in std_logic;
x_in: in std_logic_vector(W1-1 downto 0);
d_in: in std_logic_vector(W1-1 downto 0);
y_in : in std_logic_vector(W2-1 downto 0);
e_out,y_out,e1,y1:out std_logic_vector(W2-1 downto 0));
end firlms;
architecture Behavioral of firlms is
component mult
port ( dataa : in std_logic_vector(7 downto 0);
datab : in std_logic_vector(7 downto 0);
result : out std_logic_vector(15 downto 0));
end component;
subtype n1bit is std_logic_vector(W1-1 downto 0);
subtype n2bit is std_logic_vector(W2-1 downto 0);
type array_n1bit is array(0 to L-1) of n1bit;
type array_n2bit is array(0 to L-1) of n2bit;
signal d,k :n1bit;
signal emu : n1bit;
signal y,sxty:n2bit;
signal e,sxtd:n2bit;
signal x: array_n1bit;
signal p,xemu:array_n2bit;
begin
dsxt:process(d)
begin
sxtd(7 downto 0)<=d;
for k in 15 downto 8 loop
sxtd(k)<=d(d'high);
end loop;
end process;
store:process
begin
wait until clk='1';
--y <= y_in;
d <= d_in;
x(0) <= x_in;
x(1) <= x(0);
f(0)<=f(0)+xemu(0)(15 downto 8);
f(1)<=f(1) +xemu(1)(15 downto 8);
end process store;
--y<=p(0)+p(1);
ysxt:process(y)
begin
sxty(8 downto 0)<=y(15 downto 7);
for k in 15 downto 9 loop
sxty(k)<=y(y'high);
end loop;
end process;
e<=sxtd-sxty;
emu<=e(8 downto 1);
mulgen2:for i in 0 to L-1 generate
fir: mult port map (dataa=>x(i),datab=>emu,result=>xemu(i));
end generate;
--y_out<="00000000"&xemu(1);
--e_out<="00000000"&xemu(0);
e1<="00000000"&f(1);
y1<="00000000"&f(0);
end Behavioral;
library ieee;
use ieee.std_logic_1164.all;
entity mult is
end mult;
architecture fpga of mult is
begin
result<=dataa*datab;
end fpga;
It is easily fixed - just give X(0) and (1) an initial value.
signal x : array_n1bit := (others => (others => '0'));- Mark as New
--- Quote Start --- It is easily fixed - just give X(0) and (1) an initial value. signal x : array_n1bit := (others => (others => '0')); --- Quote End --- can you show me your wave form ,i'm not next to my computer
I havent made a wave form - thats your job...
--- Quote Start --- I havent made a wave form - thats your job... --- Quote End --- it work!!!!!!!!!!!!!!!!!!!!!! thanks so much
--- Quote Start --- it work!!!!!!!!!!!!!!!!!!!!!! thanks so much --- Quote End --- Hello, can you share the code please ? i'm trying to use it on a nexys 4 ddr. thank you
