21615 Discussions
quartus doesn't show connection in state machine
Hi there,
I have problem with my project, excatly with state machine.
Quartus compiles code atached below with no errors, but in state machine viewer i can see only states without connections between them.
What's wrong with project?
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; ENTITY stateMachine IS port( clk : IN std_logic; rst : IN std_logic; indicator_1_0 : IN std_logic_vector(1 downto 0); ena_init : OUT std_logic; release_register : OUT std_logic; release_result : OUT std_logic; set_to_zero_1 : IN std_logic; -- set_to_zero_2 : IN std_logic; ena_1 : OUT std_logic; ena_2 : OUT std_logic ); END stateMachine; ARCHITECTURE stateMachineArch OF stateMachine IS TYPE state_t IS (idle, P1, P2, memory_init, load, inter); SIGNAL curState, nextState : state_t; BEGIN automatStanow : process (clk, rst, indicator_1_0, set_to_zero_1, curState) VARIABLE initialisationCounter : INTEGER; BEGIN CASE curState IS WHEN idle => ena_1 <= '0'; ena_2 <= '0'; release_register <= '0'; release_result <= '0'; ena_init <= '0'; IF (indicator_1_0 = "11") THEN nextState <= P1; ELSE nextState <= idle; END IF; WHEN P1 => ena_1 <= '0'; ena_2 <= '0'; release_register <= '0'; release_result <= '0'; ena_init <= '0'; IF (indicator_1_0 = "00") THEN nextState <= P2; ELSE nextState <= idle; END IF; WHEN P2 => ena_1 <= '0'; ena_2 <= '0'; release_register <= '0'; release_result <= '0'; ena_init <= '1'; initialisationCounter := 0; WHEN memory_init => ena_1 <= '0'; ena_2 <= '0'; release_register <= '0'; release_result <= '0'; ena_init <= '1'; initialisationCounter := initialisationCounter + 1; IF (initialisationCounter = 3072) THEN nextState <= load; ELSE nextState <= memory_init; END IF; WHEN load => ena_1 <= '1'; ena_2 <= '0'; release_register <= '0'; release_result <= '0'; ena_init <= '0'; initialisationCounter :=0; IF (set_to_zero_1 = '1') THEN nextState <= inter; ELSE nextState <= load; END IF; WHEN inter => ena_1 <= '0'; ena_2 <= '1'; release_register <= '1'; release_result <= '1'; ena_init <= '0'; IF (indicator_1_0 = "11") THEN nextState <= P1; ELSE nextState <= idle; END IF; END CASE; END PROCESS; zamianaStanow: PROCESS(clk, rst) BEGIN IF (rst = '1') THEN curState <= idle; ELSIF (rising_edge(clk)) THEN curState <= nextState; END IF; END PROCESS; END stateMachineArch;
One of your states (state P2 to be precise) doesn't have an assignment for nextState, and the compiler infers latches for all states.
You should always check for 'inferred latches' in the message panel and repair the cause. I don't know of any valid use for 'latches' in user code, although some experts may differ.
Thanks a lot! It helps.
