21615 Discussions
quartus_sh does not run from Tcl Console, but can be run cmd line
my problem is that I can not run quartus_sh from Tcl Console (invalid command name "quartus_sh"), but it works from cmd line. The path to the 'bin' added to PATH variable. I use Quartus 14.0. Cannot find any solutions in the forum.
Do you know how to solve the problem?
Felixipg,
Are you trying to get the DSE feature working?
-Trukng
No, I want to run some_script.tcl before compilation. To do it I set "set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:some_script.tcl" in tcl console.
But there is no effect from setting the assignment. Now I see that quartus_sh does not work at all:
quartus_sh
Error:invalid command name "quartus_sh"
Error: while executing
Error:"unknown_original quartus_sh"
Error: ("eval" body line 1)
Error: invoked from within
Error:"eval unknown_original $cmd $args"
Error: (procedure "::unknown" line 7)
Error:"quartus_sh"
But there is no problems with running quartus_sh from command line...
--- Quote Start ---
--- Quote End ---
I encountered the same problem also. Has anyone got the solution? Please help
--- Quote Start ---
... To do it I set "set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:some_script.tcl" in tcl console ...
--- Quote End ---
Works for me. You have to put this line into your project's .qsf file, not into the tcl console.
