21615 Discussions
question about VHDL library
Hi all,
when I compile my VHDL design, there is always a error saying that * design library "book_lib" does not contain primary unit "utils_pkg"*.
Does anyone know how to fix it?Thanks
Following is my code:
library ieee,book_lib;
use ieee.std_logic_1164.all,book_lib.utils_pkg.all;
--bla bla bla
I am not familiar with VHDL, but is it supposed be a comma after "all" ?
library uses are usually ended with a semi-colon (;).
But this error means you have not compiled the utils package into the book_lib library.
--- Quote Start ---
--- Quote End ---
Not necessary: you can write a comma separated list of things to use.
use ieee.NUMERIC_BIT.all, ieee.std_logic_1164.all;
is the same as:
use ieee.NUMERIC_BIT.all; use ieee.std_logic_1164.all;
You need to find the file that contains package utils_pkg, and add it to your project, in the book_lib library.
