21611 Discussions
question about buffer model in CPLD
Hi to all,
I'm trying to run this buffer code on CPLD with 128 MicroCells, which recieves 8-byte data continueslly and outputs the data between 50 ouputs.
I recieve the following error when trying to run the simulation:
"Error: Can't fit 312 registers in device"
Can I reduce the numbers of registers in my code?
// Buffer model
module Buffer_model (Data_In, WE,
D00_Out, D01_Out, D02_Out, D03_Out, D04_Out, D05_Out, D06_Out, D07_Out, D08_Out, D09_Out,
D10_Out, D11_Out, D12_Out, D13_Out, D14_Out, D15_Out, D16_Out, D17_Out, D18_Out, D19_Out,
D20_Out, D21_Out, D22_Out, D23_Out, D24_Out, D25_Out, D26_Out, D27_Out, D28_Out, D29_Out,
D30_Out, D31_Out, D32_Out, D33_Out, D34_Out, D35_Out, D36_Out, D37_Out, D38_Out, D39_Out,
D40_Out, D41_Out, D42_Out, D43_Out, D44_Out, D45_Out, D46_Out, D47_Out, D48_Out, D49_Out);
input [7:0] Data_In;
input WE;
output [3:0] D00_Out, D01_Out, D02_Out, D03_Out, D04_Out, D05_Out, D06_Out, D07_Out, D08_Out, D09_Out,
D40_Out, D41_Out, D42_Out, D43_Out, D44_Out, D45_Out, D46_Out, D47_Out, D48_Out, D49_Out;
reg [3:0] Mem [0:49];
integer i;
initial
begin
for (i = 0; i < 50; i = i+1)
begin
Mem = 4'b0000;
end
i=50;
end
assign d00_out = mem[00];
assign d01_out = mem[01];
assign d02_out = mem[02];
assign d03_out = mem[03];
assign d04_out = mem[04];
assign d05_out = mem[05];
assign d06_out = mem[06];
assign d07_out = mem[07];
assign d08_out = mem[08];
assign d09_out = mem[09];
assign d10_out = mem[10];
assign d11_out = mem[11];
assign d12_out = mem[12];
assign d13_out = mem[13];
assign d14_out = mem[14];
assign d15_out = mem[15];
assign d16_out = mem[16];
assign d17_out = mem[17];
assign d18_out = mem[18];
assign d19_out = mem[19];
assign d20_out = mem[20];
assign d21_out = mem[21];
assign d22_out = mem[22];
assign d23_out = mem[23];
assign d24_out = mem[24];
assign d25_out = mem[25];
assign d26_out = mem[26];
assign d27_out = mem[27];
assign d28_out = mem[28];
assign d29_out = mem[29];
assign d30_out = mem[30];
assign d31_out = mem[31];
assign d32_out = mem[32];
assign d33_out = mem[33];
assign d34_out = mem[34];
assign d35_out = mem[35];
assign d36_out = mem[36];
assign d37_out = mem[37];
assign d38_out = mem[38];
assign d39_out = mem[39];
assign d40_out = mem[40];
assign d41_out = mem[41];
assign d42_out = mem[42];
assign d43_out = mem[43];
assign d44_out = mem[44];
assign d45_out = mem[45];
assign d46_out = mem[46];
assign d47_out = mem[47];
assign d48_out = mem[48];
assign d49_out = mem[49];
always @(posedge we) begin
if (i==50) i=0;
mem = Data_In[7:4];
i=i+1;
Mem[i] = Data_In[3:0];
i=i+1;
end
endmodule
Eran
It is actually 232 registers.
You defined a memory of 200 bits (reg[3:0] Mem [49:0]), together with the counter (i) you need 232 registers, which obviously do not fit into a 128- macrocell device like an EPM3128.
can I reduce the number of registers? or better to use it without any regs? I only need this buffer to recieve serial data from SPI unit and to divide it into 50 outputs (4 bits each).
