$readmemb
t=[0:0.02*10^-3:0.01];a=cos(2*pi*5*10^3*t);plot(t,a)
b=a*2^11
fid=fopen('e:\resourse.txt','wt');fprintf(fid,'%12.0f\n',b);fclose(fid)
reg [IDATA_WIDTH-1:0] fir_in[9:0];
reg [IDATA_WIDTH-1:0] temp;
initial
begin
temp=0;
$readmemb("e:\resourse.txt",fir_in);
end
I generated data with MATLAB,and then read them by $readmemb,but when simulating on modelsim,it failed,can you help me?
Depending on the simulator there might be a need to use a slash instead of a back slash in the filename. It that does not help tell us more about the error.
I not think it's this reason, because when i put the resourse on c:\ like this:
$readmemb("c:\resourse.txt",fir_in);
IT WORKS.
So it looks as if the simulator has a problem with the drive e:. Is this a network drive? What OS do you use?
