hello,
here is part of my vhdl codes. ce : in std_logic; addr : in std_logic_vector (15 downto 0); process(ce, addr) variable gpio_enable : std_logic ; begin case ce and addr(7 downto 5) is --line 58 when "001" => gpio_enable <= '1'; when others => gpio_enable <='0'; end case; end process; when i compile th design, i got an error : Error (10327): VHDL error at wb_io.vhd(58): can't determine definition of operator ""and"" -- found 0 possible definitions Can anyone help me ??Link Copied
I believe you want to concatenate rather than "and". Try this signal sub_addr : std_logic_vector(3 downto 0); -- sub_addr <= ce & addr(7 downto 5); case sub_addr is when "1001" => you might as well just use a single combinatorial assignment Kaz- Mark as New
ce : in std_logic;
addr : in std_logic_vector (15 downto 0); ----------------------------------------------------- gpio_enable <= '1' when (ce='1' and addr(7 downto 5)="001" ) else '0'; -----------------------------------------
