Annonces
21615 Discussions
some problem about FIFO
Contributeur émérite II
1 466 Visites
Hello everyone!
I created a FIFO using megaWizard.I used it to store the data from the ADC. When I used
the 1M FIFO CLK,it works properly. But I used the 2M FIFO CLK ,it don't work properly.I used
signalTap to watch it find that the input data is right,but the output data (reading from fifo) is
wrong( Maintain a certain value).
The problem confused me. I want to know the reason.
Thank you very much
0 Compliments
5 Réponses
725 Visites
I am very confused with it. Who can help me ?
0 Compliments
725 Visites
Who can help me
0 Compliments
725 Visites
Are you sampling the FIFO empty, full, and empty signals? If not I recommend you do just in case your FIFO is over/underflowing at the higher clock rate.
0 Compliments
725 Visites
Yes I think you are right. I just use MCU read the full signal , I think because the frenquency of MCU is too low. I don't understand how the fifo works. When the fifo is full, and writing it,how the fifo works.
0 Compliments
725 Visites
The FIFO has different behaviors depending on the parameterization. If you turn on overflow protection then if you write to a full FIFO the data being written into the FIFO will be dropped and the FIFO will remain full. If overflow protection is off the data will be written into the FIFO and the FIFO will go from being full to having only one word buffered (internal pointers will cross).
If the ADC data is coming in too fast then I would use a DMA to pull the contents out of the FIFO into memory then have the CPU access the data in memory. You could also take this one step further and implement multiple buffers in memory so that when the CPU is bogged down the DMA will continue to buffer more data while the CPU tries to catch up.
0 Compliments
Répondre
