Programmable Devices
21615 Discussions
some procblem about delay
I have a 50M data stream, But I need it delay 32us matching with other signals. How can I do it?
Thank you very much
At 50MHz, you need it to delay it by 1600 clock cycles, using a large shift register.
Depending on the width of your data stream, that may require quite a bit of resources.
I suggest you use the ALTSHIFT_TAPS function, so the shift register is implemented in RAM.
Thank you very much! I think that is a way, however it require so much resources.
--- Quote Start ---
--- Quote End ---
Yes. if its too many resources either:
1. redesign your system so you dont need such a large delay
2. get a bigger chip
3. Use an external ram.
