I am new to this forum. Recently I started learning Altera. I was trying to compile combinational bench mark file s27.v and during compilation I got a warning : "dff" is an internal primitive and got neglected. So in the summary there were no registers listed.
I tried putting a different name for the "dff" like dff1. Now summary shows registers but looking for a state machine view under "Tools-Netlist view" , shows a message "no state machine ". In my project I needed to see the state machine view more than any thing else. If any body knows this issue please help me.Link Copied
You should post the said benchmark for better understanding. Basically there are some prerequisites to let Quartus integrated synthesis tool recognize a state machine, that are discussed in the Quartus Handbook in chapter 6 recommended hdl coding styles under general coding guidelines, state machines. The code - if syntactically correct - should work also without recognizing a state machine.
s27 bench:
//# 4 inputs //# 1 outputs //# 3 D-type flipflops //# 2 inverters //# 8 gates (1 ANDs + 1 NANDs + 2 ORs + 4 NORs) module dff (CK,Q,D); input CK,D; output Q; wire NM,NCK; trireg NQ,M; nmos N7 (M,D,NCK); not P3 (NM,M); nmos N9 (NQ,NM,CK); not P5 (Q,NQ); not P1 (NCK,CK); endmodule module S27(GND,VDD,clk,G0,G1,G17,G2,G3); input GND,VDD,clk,G0,G1,G2,G3; output G17; wire G5,G10,G6,G11,G7,G13,G14,G8,G15,G12,G16,G9; dff DFF_0(clk,G5,G10); dff DFF_1(clk,G6,G11); dff DFF_2(clk,G7,G13); not NOT_0(G14,G0); not NOT_1(G17,G11); and AND2_0(G8,G14,G6); or OR2_0(G15,G12,G8); or OR2_1(G16,G3,G8); nand NAND2_0(G9,G16,G15); nor NOR2_0(G10,G14,G11); nor NOR2_1(G11,G5,G9); nor NOR2_2(G12,G1,G7); nor NOR2_3(G13,G2,G12); endmodule Warning: Entity "dff" will be ignored because it conflicts with Quartus II primitive name Summary Details: Flow Status Successful - Tue May 13 08:33:06 2008 Quartus II Version 7.2 Build 203 02/05/2008 SP 2 SJ Web Edition Revision Name s27 Top-level Entity Name s27 Family Stratix II Met timing requirements Yes Logic utilization < 1 % Combinational ALUTs 1 / 12,480 ( < 1 % ) Dedicated logic registers 0 / 12,480 ( 0 % ) Total registers 0 Total pins 8 / 343 ( 2 % ) Total virtual pins 0 Total block memory bits 0 / 419,328 ( 0 % ) DSP block 9-bit elements 0 / 96 ( 0 % ) Total PLLs 0 / 6 ( 0 % ) Total DLLs 0 / 2 ( 0 % ) Device EP2S15F484C3 Timing Models Final If I change "dff" to "dff1" all places in side the code with a modification in the dff module such as module dff1(clk,Q,D); input clk,D; output Q; reg Q; always @(posedge clk) begin Q<=D; end endmodule This shows 3 registers but software is not recognizing any state machines- Mark as New
I also don't recognize a state machine from this low level structural code.
I also tried with another bench mark circuit s298(traffic light circuit)
//# 3 inputs //# 6 outputs //# 14 D-type flipflops //# 44 inverters //# 75 gates (31 ANDs + 9 NANDs + 16 ORs + 19 NORs) module dff1 (clk,Q,D); input clk,D; output Q; reg Q; always @(posedge clk) begin Q<=D; end endmodule module s298(GND,VDD,CK,G0,G1,G117,G118,G132,G133,G2,G66,G67); input GND,VDD,CK,G0,G1,G2; output G117,G132,G66,G118,G133,G67; wire G10,G29,G11,G30,G12,G34,G13,G39,G14,G44,G15,G56,G16,G86,G17,G92,G18,G98, G19,G102,G20,G107,G21,G113,G22,G119,G23,G125,G28,G130,G38,G40,G45,G46,G50, G51,G54,G55,G59,G60,G64,II155,II158,G76,G82,G87,G91,G93,G96,G99,G103,G108, G112,G114,II210,II213,G120,G124,G121,II221,G126,G131,G127,II229,II232, II235,II238,G26,G27,G31,G32,G33,G35,G36,G37,G42,G41,G48,G47,G49,G52,G57, G61,G58,G65,G62,G63,G74,G75,G88,G89,G90,G94,G95,G100,G105,G104,G110,G109, G111,G115,G122,G123,G128,G129,G24,G25,G68,G69,G70,G71,G72,G73,G77,G78,G79, G80,G81,G83,G84,G85,G43,G97,G101,G106,G116,G53; dff1 DFF_0(CK,G10,G29); dff1 DFF_1(CK,G11,G30); dff1 DFF_2(CK,G12,G34); dff1 DFF_3(CK,G13,G39); dff1 DFF_4(CK,G14,G44); dff1 DFF_5(CK,G15,G56); dff1 DFF_6(CK,G16,G86); dff1 DFF_7(CK,G17,G92); dff1 DFF_8(CK,G18,G98); dff1 DFF_9(CK,G19,G102); dff1 DFF_10(CK,G20,G107); dff1 DFF_11(CK,G21,G113); dff1 DFF_12(CK,G22,G119); dff1 DFF_13(CK,G23,G125); not NOT_0(G28,G130); not NOT_1(G38,G10); not NOT_2(G40,G13); not NOT_3(G45,G12); not NOT_4(G46,G11); not NOT_5(G50,G14); not NOT_6(G51,G23); not NOT_7(G54,G11); not NOT_8(G55,G13); not NOT_9(G59,G12); not NOT_10(G60,G22); not NOT_11(G64,G15); not NOT_12(II155,G16); not NOT_13(G66,II155); not NOT_14(II158,G17); not NOT_15(G67,II158); not NOT_16(G76,G10); not NOT_17(G82,G11); not NOT_18(G87,G16); not NOT_19(G91,G12); not NOT_20(G93,G17); not NOT_21(G96,G14); not NOT_22(G99,G18); not NOT_23(G103,G13); not NOT_24(G108,G112); not NOT_25(G114,G21); not NOT_26(II210,G18); not NOT_27(G117,II210); not NOT_28(II213,G19); not NOT_29(G118,II213); not NOT_30(G120,G124); not NOT_31(G121,G22); not NOT_32(II221,G2); not NOT_33(G124,II221); not NOT_34(G126,G131); not NOT_35(G127,G23); not NOT_36(II229,G0); not NOT_37(G130,II229); not NOT_38(II232,G1); not NOT_39(G131,II232); not NOT_40(II235,G20); not NOT_41(G132,II235); not NOT_42(II238,G21); not NOT_43(G133,II238); and AND2_0(G26,G28,G50); and AND2_1(G27,G51,G28); and AND3_0(G31,G10,G45,G13); and AND2_2(G32,G10,G11); and AND2_3(G33,G38,G46); and AND3_1(G35,G10,G11,G12); and AND2_4(G36,G38,G45); and AND2_5(G37,G46,G45); and AND2_6(G42,G40,G41); and AND4_0(G48,G45,G46,G10,G47); and AND3_2(G49,G50,G51,G52); and AND4_1(G57,G59,G11,G60,G61); and AND2_7(G58,G64,G65); and AND4_2(G62,G59,G11,G60,G61); and AND2_8(G63,G64,G65); and AND3_3(G74,G12,G14,G19); and AND3_4(G75,G82,G91,G14); and AND2_9(G88,G14,G87); and AND2_10(G89,G103,G96); and AND2_11(G90,G91,G103); and AND2_12(G94,G93,G13); and AND2_13(G95,G96,G13); and AND3_5(G100,G99,G14,G12); and AND3_6(G105,G103,G108,G104); and AND2_14(G110,G108,G109); and AND2_15(G111,G10,G112); and AND2_16(G115,G114,G14); and AND2_17(G122,G120,G121); and AND2_18(G123,G124,G22); and AND2_19(G128,G126,G127); and AND2_20(G129,G131,G23); or OR4_0(G24,G38,G46,G45,G40); or OR3_0(G25,G38,G11,G12); or OR4_1(G68,G11,G12,G13,G96); or OR2_0(G69,G103,G18); or OR2_1(G70,G103,G14); or OR3_1(G71,G82,G12,G13); or OR2_2(G72,G91,G20); or OR2_3(G73,G103,G20); or OR4_2(G77,G112,G103,G96,G19); or OR2_4(G78,G108,G76); or OR2_5(G79,G103,G14); or OR2_6(G80,G11,G14); or OR2_7(G81,G12,G13); or OR4_3(G83,G11,G12,G13,G96); or OR3_2(G84,G82,G91,G14); or OR3_3(G85,G91,G96,G17); nand NAND3_0(G41,G12,G11,G10); nand NAND3_1(G43,G24,G25,G28); nand NAND4_0(G52,G13,G45,G46,G10); nand NAND4_1(G65,G59,G54,G22,G61); nand NAND4_2(G97,G83,G84,G85,G108); nand NAND4_3(G101,G68,G69,G70,G108); nand NAND2_0(G106,G77,G78); nand NAND4_4(G109,G71,G72,G73,G14); nand NAND4_5(G116,G79,G80,G81,G108); nor NOR2_0(G29,G10,G130); nor NOR4_0(G30,G31,G32,G33,G130); nor NOR4_1(G34,G35,G36,G37,G130); nor NOR2_1(G39,G42,G43); nor NOR3_0(G44,G48,G49,G53); nor NOR2_2(G47,G50,G40); nor NOR2_3(G53,G26,G27); nor NOR3_1(G56,G57,G58,G130); nor NOR2_4(G61,G14,G55); nor NOR4_2(G86,G88,G89,G90,G112); nor NOR3_2(G92,G94,G95,G97); nor NOR2_5(G98,G100,G101); nor NOR2_6(G102,G105,G106); nor NOR2_7(G104,G74,G75); nor NOR2_8(G107,G110,G111); nor NOR2_9(G112,G62,G63); nor NOR2_10(G113,G115,G116); nor NOR3_3(G119,G122,G123,G130); nor NOR3_4(G125,G128,G129,G130); endmodule With the modification of "dff1" in this code, it's compiling properly but same problem. I am able to see RTL viewer but not state machine viewer. Please advise me...- Mark as New
To my opinion, the state machine viewer isn't intended for interpreting low level structural code as state machine. It works with usual HDL state machine constructs as discussed in the Quartus manual.
