21615 Discussions
stmmac_dvr_probe: warning: cannot get CSR clock
I'm trying to boot from QSPI cyclone V soc devkit, i prepared and flash the QSPI with the files preloader, socfpga.dtb, u-boot.img, uImage (cannot read zImage), socfpga.rootfs.jffs2
in ubuntu host machine
the boot process hand up with "stmmac_dvr_probe: warning: cannot get CSR clock" massage
U-Boot SPL 2012.10 (Nov 21 2013 - 13:36:56)
SDRAM: Initializing MMR registers
yehuda
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SF: Detected N25Q00 with page size 65536, total: 134217728
U-Boot 2012.10 (Nov 28 2013 - 10:34:59)
CPU : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone 5 Board
DRAM: 1 GiB
MMC: DESIGNWARE SD/MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
SF: Detected N25Q00 with page size 65536, total: 134217728# # Booting kernel from Legacy Image at 00007fc0 ...
Image Name: Linux-3.12.0-rc3-00186-gc31eeac
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2182032 Bytes = 2.1 MiB
Load Address: 00008000
Entry Point: 00008000# # Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
XIP Kernel Image ... OK
OK
Loading Device Tree to 0fffa000, end 0fffef8a ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Linux version 3.12.0-rc3-00186-gc31eeac (yehuda@DT-Cyclone5) (gcc version 4.7.3 20121106 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2012.11-20121123 - Linaro GCC 2012.11) )# 1 SMP Thu Nov 28 08:20:04 IST 2013
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Altera SOCFPGA, model: Altera SOCFPGA Cyclone V
Truncating RAM at 00000000-3fffffff to -2f7fffff (vmalloc region overlap).
Memory policy: ECC disabled, Data cache writealloc
BUG: mapping for 0xfffec000 at 0xfffec000 out of vmalloc space
PERCPU: Embedded 8 pages/cpu @c0a45000 s11328 r8192 d13248 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 193040
Kernel command line: console=ttyS0,57600 root=/dev/mtdblock1 rw rootfstype=jffs2
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 766844K/778240K available (2931K kernel code, 150K rwdata, 880K rodata, 187K init, 215K bss, 11396K reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 k
fixmap : 0xfff00000 - 0xfffe0000 ( 896 k
vmalloc : 0xf0000000 - 0xff000000 ( 240 M
lowmem : 0xc0000000 - 0xef800000 ( 760 M
modules : 0xbf000000 - 0xc0000000 ( 16 M
.text : 0xc0008000 - 0xc03c0e34 (3812 k
.init : 0xc03c1000 - 0xc03efc40 ( 188 k
.data : 0xc03f0000 - 0xc0415ab8 ( 151 k
.bss : 0xc0415ab8 - 0xc044b800 ( 216 k
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:16 nr_irqs:16 16
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Console: colour dummy device 80x30
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0xc02c8e48 - 0xc02c8ea0
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410030c9, AUX_CTRL 0x02060000, Cache size: 512 kB
of_amba_device_create(): amba_device_add() failed (-2) for /soc/amba/pdma@ffe01000
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it
PTP clock support registered
Switched to clocksource timer3
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
NTFS driver 2.1.30 [Flags: R/W].
msgmni has been set to 1497
io scheduler noop registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
ffc02000.serial0: ttyS0 at MMIO 0xffc02000 (irq = 194, base_baud = 6250000) is a 16550A
console [ttyS0] enabled
brd: module loaded
stmmac - user ID: 0x10, Synopsys ID: 0x37
Ring mode enabled
DMA HW capability register supported
Enhanced/Alternate descriptors
Enabled extended descriptors
RX Checksum Offload Engine supported (type 2)
TX Checksum insertion supported
Enable RX Mitigation via HW Watchdog Timer
can someone please advise what do i do wrong?
