Trying to use the code below: module portlist_localparam# ( parameter aPARAM = 1, localparam aLOCAL = 2 ) endmodule Get error: Error (10170): Verilog HDL syntax error at portlist_localparam.sv(4) near text "localparam"; expecting an identifier ("localparam" is a reserved keyword ) is that a valid error? how to solve for system verilog? Thanks in advance, Best regards AngelLink Copied
The parameter list of a Verilog or systemVerilog module only accept "parameter".
So just replace "localparam" with "parameter"
