Programmable Devices
21615 Discussions
time limited sof file
I have still not purchased the license for NIOS II IP. So right now i get the _time_limited.sof file output from the Quartus 9.0 sp1 edition.
My question is can the time_limited.sof file be converted to flash format using the sof2flash utility ?
Apparantly I am getting an error during conversion process .. something that looks as follows
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="$SOPC_KIT_NIOS2/examples/v
hdl/DBC3C40/epcs_boot1/DBC3C40_standard_time_limited.sof" --output="DBC3C40_stan
dard_time_limited.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert C:/altera/90sp1/nios2eds/exampl
es/vhdl/DBC3C40/epcs_boot1/DBC3C40_standard_time_limited.sof DBC3C40_standard_ti
me_limited.rbf
File C:/altera/90sp1/nios2eds/examples/vhdl/DBC3C40/epcs_boot1/DBC3C40_standard_
time_limited.sof contains one or more time-limited megafunctions that support th
e OpenCore Plus feature that will not work after the hardware evaluation time ex
pires. Refer to the Messages window for evaluation time details.
Info: SRAM Object File C:/altera/90sp1/nios2eds/examples/vhdl/DBC3C40/epcs_boot1
/DBC3C40_standard_time_limited.sof contains time-limited megafunction that suppo
rts OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2
rts OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCEC
rts OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0xBCE1
SOF Data item missing input file
Error: Convert Programming Files was NOT successful -- refer to messages that ap
pear above this message for more information
Can somebody please help me out
Rohit
No.
Time limited means that you can not create files that can be used for production purposes to enable you to sell your design
instead you need a connection between your pc and the target.
