21256 Discussions
traffic generator without example design
CosmoKramer
Can I connect traffic generator to emif ip itself instead of using example design?
sstrell
No, you have to create an example design.  It's not a standalone IP you can manually add.  You could, of course, create the example design and replace everything other than the traffic generator.
CosmoKramer
Thank you for replying. I understand TG is not ip.
However, I should be able copy TG files and move them to correct location and instantiate TG as a module and connect it to emif ip in our source code. right?
AdzimZM_Intel
Hi Sandy,
"However, I should be able copy TG files and move them to correct location and instantiate TG as a module and connect it to emif ip in our source code. right?"
  • Yes you should be able to copy TG and connect to EMIF IP in your design.
Adzim
sstrell
The TG is a Platform Designer component, so if you're saying you want to connect it to the rest of your design outside of Platform Designer, that's going to be a bit tricky.  Adzim thinks it's possible, but I'm not sure it will work.
