21602 Discussions
Replacement for Intel / Altera EPM570F256C5N
vankammen
Experiencing a part allocation issue for the Intel / Altera EPM570F256C5N CPLD.  Any suggestions for a drop-in replacement?
ak6dn
Valued Contributor III
Tried I temp vs C temp? Faster or slower speed grade?
Mouser has 2pcs of C3N in stock as of the time of this post. I suspect you want more than two tho. Lead time is listed as 53 weeks.
vankammen
I currently use commercial temp so it is possible to switch to industrial or automotive temp (with a cost penalty) - I will check with distributors on part availability.
What would be the impact of changing the speed grade?  Would the I/O timing change at all if I moved to a faster speed grade?  The I/O timing is critical for my application.
ak6dn
Moving to a faster (or slower) speed grade will have a minor effect on the I/O timing. Mostly speed grade effects the internal core timing.
If your timing is really critical tho, I would rerun simulations using the alternate device timing info selected.
Ash_R_Intel
Hi, If you are moving from slower to faster speed grade device, then there will be no risk from timing perspective.
For faster to slower device, you should re-run the Timing Analysis only for the new device to check if you have sufficient margins and all constraints are met or not.
A way to do that is to create a Timing Netlists for different speed grades in Timing Analyzer tool and check the performance.
Ash_R_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
