21611 Discussions
unable to create symbol file for current file (Verilog HDL file) in Quartus IIweb13.1
I am unable to create symbol file for current file (Verilog HDL file) in Quartus II web edition 13.1.
Compilation report shows 'Data not available'.
plz help me !
why not post the verilog file here...
Hi Tricky,
I am trying to run 'My_first_fpga' tutorial on my cyclone III starter board, verilog code is as below:
// This is an example of a simple 32 bit up-counter called simple_counter.v
// It has a single clock input and a 32-bit output port
module simple_counter (input clock , output reg [31:0] counter_out);
always @ (posedge clock)// on positive clock edge
begin
counter_out <=# 1 counter_out + 1;// increment counter
end
endmodule// end of module counter
have you created a project?
I am also doing that tutorial and I have the same problem. I created a project (just as instructed). Chitranshvarun, were you able to resolve this issue?
Perhaps I should add that I am using this EP4CE6E22C8N FPGA rather than one of the recommended FPGAs...
Thanks in advance,
Chandran
