Hi , i have problem with SOPC builder. On first picture label : "Error: cpu_0: Exception is too large for the selected memory" Project : https://yadi.sk/d/q4-scbq13gsbnd
hello
the reason is that your memory is too small. you have just 20 byte on onchip_memory2_0. what a hell do you think you can do with it.- Mark as New
--- Quote Start --- hello the reason is that your memory is too small. you have just 20 byte on onchip_memory2_0. what a hell do you think you can do with it. --- Quote End --- I changed the memory settings , nothing has changed
Thanks , I solved this problem long ago , but now i have another. In IDE : image on board is newer than expected
ok then, congratulations.
about your next problem. I don't know where/when you meet this message. you should describe detail.- Mark as New
--- Quote Start --- ok then, congratulations. about your next problem. I don't know where/when you meet this message. you should describe detail. --- Quote End --- In nios ii ide , when i try to run project
upload your project again if you can.
