21611 Discussions
what FPGA CPLD cable driver can I use with most devices
TRaym1
Hi I just downloaded the Intel Quartus Prime software I booted that and then it tells me I need to install device drivers, that is rather vague for newbies Im one so I assume the software is referring to the device Cable drivers is that correct.  Im using a CPLD prototyper FPGA device, I seem to remember this was used with a Cable that needs a cable driver.
 The issue is Im not using any devices Intel lists, instead Im  using a device that used to be made by Bil Herd which is a CPLD FPGA, Bil made these himself, but it seems he quit making these neat little CPLD devices.  Bil BTW has some past Hackaday videos and he used this very CPLD device and it was working, only the device was recognized as UNKNOWN DEVICE.
So also then when you first install Quartus Prime etc it first iforms you of installing device drivers, so should I just put the device driver in the main directory that is in the dialogue box?
sstrell
Quartus and the Programmer are not going to be able to program some random no-name device.  Not sure what you're expecting here.
The drivers installed with Quartus use the USB Blaster hardware (either dev kit integrated or USB-to-JTAG (10 pin) converter) to program Intel FPGA devices.
NurAiman_M_Intel
Intel Quartus Prime only use Intel USB Blaster to program Intel FPGA device.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
