21615 Discussions
what is the procedure to change notepad to default text editor for modelsim? plz specify each step explicitly.
NVARA1
SAR
Highlight the (.v/.vhd) file by click on it. Then, right mouse button click. Select "Properties" and click on "Change"
Next, select any software as you like...ModelSim or notepad.
MuhammadAr_U_Intel
image.pngHi @SAR​ can you double check the steps you describe, I don't see an option to change Text Editor, but to change the file type.
This is using Modelsim Intel Edition 10.5b
Snapshot below.
MuhammadAr_U_Intel
image.png@NVARA1​ please try the steps below.
From Modelsim Intel menu go to Tools > Edit Preferences
Look for Editor
Click change value and point to the executable of your TextEditor.
SAR
Modelsim->Tools->preferences->By Name->select "main"->select"Editor"
And follow the images posted above.
