21602 Discussions
why the module is synthesized away?
hello,
i got a problem, here is the my code : attachment 1
and part of the top module is below: attachment 2
Check reset and clock signals into your design, make sure your module is not stuck in to the reset state.
A design entity is removed in synthesis, if no output pin depends directly or indirectly on it's operation or if it has constant output.
Cause the design is incomplete, I'm unable to see, what is the reason here. I guess, that all output data from the said module gets lost in other parts of the design, that are missing in the posted code. But it can be usually determined from synthesis warnings.
--- Quote Start ---
--- Quote End ---
I have brief look to your source code. It lookslike that the problem is your address generation. It looks to me that READ_RAM_ADDR is never set to "1"
//ram address
always@(negedge CLOCK or negedge RESET_X)
begin
if(!RESET_X)
begin
READ_RAM_ADDR <=# P_DLY 10'b0; // GPK
end
else if(READ_RAM_ADDR == 1'b1) begin
if(clkcnt == 6'd10)
READ_RAM_ADDR <=# P_DLY 10'd1;
if(clkcnt == 6'd20)
READ_RAM_ADDR <=# P_DLY 10'd2;
if(clkcnt == 6'd30)
READ_RAM_ADDR <=# P_DLY 10'd3;
else
READ_RAM_ADDR <=# P_DLY READ_RAM_ADDR;
end
else
READ_RAM_ADDR <=# P_DLY 6'd0;
end
--- Quote Start ---
if(clkcnt == 6'd10)
end
--- Quote End ---
sorry, i make a mistake, here READ_RAM_ADDR is READ_RAM_ENABLE.
but its not the point.thankyou.
--- Quote Start ---
--- Quote End ---
thank you, i think its the point, according to you suggestion, i will check my design and make sure if this is the point of the problem.thanks again.
--- Quote Start ---
--- Quote End ---
maybe I'm wrong, but I think your clkcnt is the problem:
//clkcnt
begin
if(!RESET_X)
begin
clkcnt <=# P_DLY 6'd0;
end
else if(READ_RAM_ENABLE == 1'b1) begin
if(clkcnt == 6'd40)
clkcnt <=# P_DLY clkcnt + 6'd1;
else
clkcnt <=# P_DLY clkcnt;
end
else
clkcnt <=# P_DLY 1'b0;
end
The counter will never count, because after reset the clkcnt is set to "0".
Your counter can only count at clkcnt = 40, but you will never reach this value.
thank you, pletz. I have crrect it , it should be
"if(clkcnt <= 6'd40)", my popurse is that,as the signal is enable, "READ_RAM_ENABLE == 1'b1", and when the counter is less than 40, then it will add 1, when it reach to 40, it will be keep the value "40".
