- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I'm trying to setup a RAID 5 array. I've got my motherboard configured to use Intel RST. My 3 new drives all show up in Storage System View in the Intel Optane Memory and Storage Management app.
However, the option to "Create RAID Volume" is grayed out.
I've attached the system diagnostics file and a screenshot.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello, DaveA.
Thank you for posting on the Intel Community Support Forums.
I will move your thread to the dedicated Intel RST community section so you can get this resolved as soon as possible.
Bruce C.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello, DaveA.
Can you try to create a RAID5 volume with the motherboard BIOS utility?
On my PC, if my HDD is 4 or less, it can be created by the BIOS utility.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DaveA,
We are going to work on this issue, in the meantime, could you please confirm if you have enabled RAID in BIOS as well? In case you have not, you may be able to do that by following either of these methods:
- Press F2 after the Power-On-Self-Test (POST) memory test begins.
- Select the Configuration menu, then the SATA Drives menu.
- Set the Chipset SATA Mode to RAID.
- Press F10 to save the BIOS settings and exit the BIOS Setup program.
OR
- Select the Advanced menu, then the Drive Configuration menu.
- Set the Drive Mode option to Enhanced.
- Enable Intel® RAID Technology.
Steven G.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I can confirm that I have RAID enabled in the BIOS
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello, Dave A.
"Microsoft Storage Space" is evil.
I had a hard time because the HDD was not displayed in "Disk Management". The cause is that the HDD was in the "storage space".
Is the HDD you are trying to RAID in the "storage space"? I don't think it's possible. Delete the HDD from "Storage Space".
By Google Translate
日本語原文
こんにちは、DaveA。
「MicrosoftStorageSpace」は悪です。
「ディスク管理」にHDDが表示されなかったので苦労しました。 原因は、HDDが「ストレージスペース」にあったことです。
RAIDしようとしているHDDは「ストレージスペース」にありますか? それは不可能だと思います。 「ストレージスペース」からHDDを削除てください。
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thank you for your response.
I will work on this case and as soon as I have an update, I will let you know.
Steven G.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DaveA,
In order to continue with our research, please provide the following information:
- Intel® RST driver version currently installed.
- Make and model of your system motherboard.
- Could you please provide pictures of the BIOS screen where it shows the drives are recognized by the system as RAID On/Ready? We have performed a test with the same issue, and it was related to BIOS configuration.
Steven G.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Motherboard is ASUSTeK Computer INC. PRIME B250M-C
Intel Optane Memory and Storage Management driver is version 18.6.1.1016 Date: 7/23/2021. I'm assuming this is the RST driver. Please advise if not. Maybe that's part of the problem.
The intel drive and support assistant tells me that I have an update available: for Intel RST Driver. The new version is 16.8.3.1003 dated 3/19/2019. This update fails to install. When this update attempts to install I get a warning that I already have a new version installed. Logs of install are attached in case that might help.
I'll send a screenshot of the BIOS next.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Found the Intel RST driver in the device manager. It is also version 18.36.1.1016, dated: 7/23/2021.
photo of bios screen attached
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Did you try creating the array from that BIOS scene? Use space bar to select each of the drives to be included and then start the create operation.
Hope this helps,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DaveA,
Steven G.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I did check the previous post in regards to selecting drives in the BIOS via the spacebar in order to add to a raid array. With my BIOS when I've got the drive highlighted if I select the spacebar nothing happens. Maybe my BIOS works differently, I have no idea.
So, yes I still need help.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Your picture is cut off. What else is on the screen?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Nothing that matters is missingNothing of consequence was cutoff
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I also included what is seen if I select the drive. For some reason these drives won't go into a RAID array
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Ah, this makes more sense. This is just a BIOS display scene, not the actual RAID console. Once you have the SATA Mode parameter set to RAID, you should be able to do a <CTRL-I> during BIOS POST and enter the actual Intel RAID BIOS Extension.
Hope this helps,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello DaveA,
Were you able to check the previous post from Scott?
Let us know if you have any update or still need assistance.
Steven G.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
