- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
When connecting to the RAID controller configuration screen from the BIOS of our DELL OptiPlex 3050, we don't have the option to create a RAID volume. Both disks we have installed are visible (RaidController.PNG).
It's not according to the instructions on how to setup the RAID (http://www.dell.com/support/article/sln155274/how-to-configure-raid-on-a-dell-desktop-pc?lang=en How to Configure Raid on a Dell Desktop PC | Dell US ) where we see an option "Create RAID Volume" (Point 4.3 in Section "Newer Desktops sold with Windows 8/10 installed on UEFI")
In the Disk Manager (DiskManager.PNG) we can see that on Disk 0 we have the OS (Windows 10 Pro) installed and still some unpartitioned space. The entire Disk 1 is unpartitioned.
Also in Windows in the "Intel Rapid Storage Technology" application we don't see a link to create the volume (RSTwithoutLink.PNG). It seem to me that it should look rather like on the picture "RSTwithLink.PNG" that I found on the internet.
In the BIOS we have SATA Operation set to "RAID On".
Thanks for any input. If I can't make this work I will have to buy an additional dedicated RAID controller.
Message was edited by: Martin Bühler (SystemReport.txt added)
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello MartinBuhler,
Thank you for joining the Rapid Storage Technology Community. I am sorry to hear you are having issues with this matter.
Could you please help us with the information below? This will help to address this behavior in the most accurate way.
- Did you install the operating system after setting the SATA mode to RAID?
- I noticed that there is a newer version available from Dell Site. I recommend uninstalling your current one, restart your computer and then to install the following version: http://www.dell.com/support/home/us/en/04/drivers/driversdetails?driverId=66MG5 Intel Rapid Storage Technology Driver and Management Console Driver Details | Dell US
Amy C.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Amy C,
thanks for your reply. Yes we did a fresh installation of the OS after setting the SATA mode to "RAID On".
I will check the functionality with the updated version of the driver and let you know the result.
Best Regards, Martin
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Amy C
We installed the version you proposed with the same result.
The view from Windows is the same as from the BIOS level RAID interface, we see the disk and don't have any option to create a RAID.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I am sorry to hear that Martin!
I double checked your computer specs and noticed that your chipset model is the Intel® B250 Chipset, based on that I did a research and found that there is note on the datasheet that states the following: "Supports Intel® RST and System Acceleration with Intel® Optane Technology(without RAID support)". And, this could confirm that fact that the option to create a RAID volume is not present is related to that statement. Is there any chance to confirm this with Dell if your particular computer model supports RAID?
Find the documents I used below:
OptiPlex 3050 Tower, Small Form Factor and Micro specs: http://i.dell.com/sites/doccontent/shared-content/data-sheets/en/Documents/OptiPlex-3050-Towers-Technical-Specifications.pdf http://i.dell.com/sites/doccontent/shared-content/data-sheets/en/Documents/OptiPlex-3050-Towers-Technical-Specifications…
Intel® B250 Chipset datasheet: https://www.intel.com/content/www/us/en/chipsets/200-series-chipset-pch-datasheet-vol-1.html?wapkw=200+series+chipset Datasheet, Vol. 1: Intel® 200 and Z370 Series Chipset Families PCH. See page 20 to check the statement mentioned above.
Amy C.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Amy C.
We are still trying to confirm while indeed the documents you provided show this it is "as designed" that we can't create a RAID on that PC model.
Thanks for your kind assistance anyway. It helped me to prove to our internal customer that we need other hardware to be able to have the needed RAID.
So in the end we chose another device to cover our requirements and I can close the case.
Have a nice day! Martin
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sure Martin, I am glad to hear it helped you.
And, if you need further assistance let us know.
Amy C.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
