Rapid Storage Technology
Intel® RST, RAID
Disable RST
Kevynjr
Principiante
35.260 Vistas
Hi all,
Could you please help me disable RST on Dell Latitude 5411? I want to install ubuntu wipe out windows total. This laptop does not show anywhere where I can disable the RST technology.
Please see attached
0 kudos
6 Respuestas
Maria_R_Intel
Moderador
35.237 Vistas
Hello Kevynjr,
Thank you for posting on the Intel* Community.
In order to disable Intel* RST, you need to access the BIOS and set SATA mode as IDE or AHCI, for this configuration you should contact the Equipment Manufacturer (Dell*) for the proper guidance on the BIOS.
Maria R.
Kevynjr
Principiante
35.228 Vistas
Hi Maria_R_Intel
Thank you for your respond - I have attached a snap shot of the BIOS set up on and I can't seem to find where to change that SATA to IDE or AHCI.
Kindly show me if the option is there on the attached pdf?
If I am to go contact dell please share the link to contact dell.
thank you,
Kevynjr
n_scott_pearson
Superusuario
35.217 Vistas
Please expand the System Configuration and Maintenance sections and take pictures of the subentries for us. We're looking for the SATA section, which may be under a Devices section. I would expect these to be under System Configuration, but you never know...
Kevynjr
Principiante
35.210 Vistas
Hi Scott,
Apologies for responding late - please see attached.
Thank you,
Kevynjr
Maria_R_Intel
Moderador
35.162 Vistas
Hello Kevynjr,
Thank you for the pictures.
I noticed with the pictures, that you have the option to disable RST under System Configuration > SATA Operation > You will be able to see the options Disable or AHCI, you can use both to disable RST, keep in mind that you will have to reinstall the Operating System after changing this option.
Please be aware that we do not handle the BIOS specifications of your system, and the best course of action is to contact them for more specific steps on its configuration. Please use this link to reach Dell Supporthttps://www.dell.com/support/home/en-us
Maria R.
Maria_R_Intel
Moderador
35.145 Vistas
Hello Kevynjr,
Maria R.
Responder
