Rapid Storage Technology
Intel® RST, RAID
How should I fix my hdd?
LSea0
I've lost my HDD after installing rapid storage technology. It's using it as recovery drive. how should I fix it?
my system is acer predator G9-793
tnx,
AlHill
Why did you install RST? Do you have RAID or Optane? If not, you do not need RST.
Did you have a backup?
Doc
LSea0
Dear sir,
thank you for your feedback.
Actually, I just changed my windows and after that I downloaded my computer driver's from acer website and I am not familiar with RAID or Optane.I just want to have access to my HDD again and no I don't have any backups but being able to use it again is priority. Is there any way?
tnx, (sorry for bad english)
LSea0
Does anyone Know what should I do?
AdrianM_Intel
Hello LSea0,
Thank you for posting on the Intel® communities.
You might try the following:
Try to enter to Intel® Rapid Storage Technology (Intel® RST) option ROM
You can access it by pressing Ctrl + i when the computer when your computer is posting once you get there:
  • Mark the drive as "Non-RAID".
  • Reboot your system.
  • Make sure you have a back up since your information can be lost.
Note: if the key combination Ctrl + i does not work to access Intel® Rapid Storage Technology (Intel® RST) option ROM you might need to contact the system manufacturer to get the appropriate steps to access it.
Adrian M.
AdrianM_Intel
Hello LSea0,
Were you able to check the previous post?
Let me know if you need more assistance.
Adrian M.
LSea0
Hi sir,
I tried to access the option rom but ctrl+i didn't work for me.
AdrianM_Intel
Hello LSea0,
Thank you for your input.
I will recommend you to contact the system manufacturer of your computer since this key combination to access the  Intel® Rapid Storage Technology (Intel® RST) option ROM can be different/customized depending on the manufacturer, once you get access to it followed the steps suggested.
Hope this helps.
Adrian M.
