Rapid Storage Technology
Intel® RST, RAID
2188 Discussions
Intel Raid 10 Failed - 2 out of 4 drives suddenly became non-members of array
I have an Asus P8P67 board and created a RAID 10 array with 4 x 3TB drives. I had intel driver version 10.5.1.1001 and updated to latest drivers 10.8.0.1003. Then I proceeded to update my BIOS from 1704 to 2103. Upon restart I went into bios to reset settings to the way they were before but upon restart my array was in failed status and two of the drives were non-member drives.
All drives are still there and working normally. I am afraid to change anything because I know the data is there because there is nothing different on the drives but for some reason they are not all part of array anymore. The only difference I see is that Intel software is showing missing drives with serial numbers of the connected drives but an additional ":0" at the end of serial number.
I have attached below the system info file created by intel software which details all my drives.
Thanks in advance for your help.
System Report
System Information
OS name: Microsoft Windows 7 Ultimate
OS version: 6.1.7601 Service Pack 1 7601
System name: MACHINA
System manufacturer: System manufacturer
System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3.301 GHz
BIOS: American Megatrends Inc., 2103
Intel® Rapid Storage Technology
Kit installed: 10.5.1.1001
User interface version: 10.5.1.1002
Language: English (United States)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 10.5.0.1034
Driver version: 10.5.1.1001
ISDI version: 10.5.1.1002
Device Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: RAID10
Number of disks: 4
Array disk: MJ1321YNG0YVAA
Array disk: MJ1311YNG26HEA
Array disk: MJ1311YNG0W57A:0
Array disk: MJ1321YNG0Y7YA:0
Status: Failed
Type: RAID 10
Data stripe size: 64 KB
Write-back cache: Enabled
System volume: No
Initialized: Yes
Verification errors found: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Parent array: Array_0000
Number of disks: 4
Disk on port 1
Port location: Internal
Status: Normal
Type: Hard disk
Usage: Available
Serial number: 5VG0JQ41
Model: ST9250410ASG
Firmware: 0002SDM1
System disk: No
Password protected: No
Native command queuing: Yes
SATA transfer rate: 3 Gb/s
Disk on port 2
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: MJ1321YNG0YVAA
Model: Hitachi HDS5C3030ALA630
Firmware: MEAOA580
System disk: No
Disk on port 3
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: MJ1311YNG26HEA
Firmware: MEAOA580
System disk: No
Disk on port 4
Status: Normal
Type: Hard disk
Usage: Available
Serial number: MJ1311YNG0W57A
Firmware: MEAOA580
System disk: No
Disk on port 5
Status: Normal
Type: Hard disk
Usage: Available
Serial number: MJ1321YNG0Y7YA
Firmware: MEAOA580
System disk: No
Disk on port Unknown
Port location: Unknown
Status: Missing
Type: Hard disk
Usage: Array disk
Serial number: MJ1311YNG0W57A:0
Model:
Firmware:
System disk: No
Disk data cache: Ena...
Allan_J_Intel1
Hi there!
The problem is that you booted your computer without changing SATA mode to RAID right after updating BIOS.
When you updated BIOS the computer defaulted to IDE and this is why you have a RAID failed status. You will need to recreate your RAID from scratch, no data and structure is available.
Allan.
