I havent been able to install AHCI driver for my laptop and its working like crap, the disk charge rises to 100% wich makes practically impossible to work, thanks in advance for any help that can be provided,
Sorry for my bad English, I'm From Colombia
- Tags:
- AHCI
What process or program is actually causing the HDD accesses? Windows 10 task manager should also show this.
Anonymous
Not applicable
08-05-2015
03:56 PM
Verify with your laptop manufacturer if there are available compatible drivers with Microsoft® Windows 10. The Intel® Rapid Storage Technology driver is necessary if you are planning to create a RAID volume, use SMART cache memory and Rapid Start Technology.
Run Microsoft® Windows update utility in order to update the drivers of your laptop.
Mike C
